RFS on NVRAM (RTEMS 4.10.1)
Oleg Moroz
oleg.moroz at aol.com
Wed Feb 1 14:29:24 UTC 2012
all bytes should be 0xff before formatting. Because beginning of nvdisk
is checksum area for each block in data area of NVDISK.
|ffff,ffff,ffff,ffff| checksums area
data area
|ff,ff,ff,ff,ff,ff,ff,ff| block
checksum of block contains only 0xff is 0xffff and nvdisk checking will
be passed.
> Hi All,
> When we try to mount the RFS on a NVRAM having non 0xFF data it crashes. We cannot see any error on MMI but the CPU gives bus exception indicating the software is trying to write to a write protected location.
> We use the below configuration and have 256KB of NVRAM(actually SRAM).
> const rtems_nvdisk_config rtems_nvdisk_configuration[] =
> block_size: NVRAMDISK_BLOCK_SIZE, //512
> device_count: 1,
> devices:&rtems_nv_heap_device_descriptor[0],
> flags: 0,
> info_level: 0
> If we manually intialize the NVRAM first with 0XFF and then mount RFS it works without any problem. Can anyone please guide us how to fix this problem?
> Thanks& Best Regards,
> Viral.
> rtems-users mailing list
> rtems-users at rtems.org
