How to get the multi-lib options of a RTEMS installation
Fri Feb 10 14:53:17 UTC 2012
On Fri, Feb 10, 2012 at 3:24 AM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> On 02/10/2012 08:53 AM, Sebastian Huber wrote:
>> On 02/10/2012 08:37 AM, Sébastien Bourdeauducq wrote:
>>> On 02/10/2012 04:05 AM, Ralf Corsepius wrote:
>>>> On 02/09/2012 05:44 PM, Sebastian Huber wrote:
>>>>> Is there a why to get the GCC options which were used to generate these
>>>>> multi-libs?
>>>> No. That's not how multilibs work.
>>>> The multilib directories are gcc internal default library search-paths,
>>>> GCC switches to when it finds certain combinations of flags in the
>>>> CFLAGS/LDFLAGS being passed to it.
>>>> I.e. there is a "multilib options" -> "multilibdir" transformation,
>>>> but there is no reverse transformation.
>>> Seems there is:
>>> $ lm32-rtems4.11-gcc -print-multi-lib
>> Thanks, this is exactly the option I was looking for.
> This is the flags->dirs mapping I was talking about.
> The inverse mapping is invalid.
So does iterating over all those flags build multilibs of libfancy
that matches all the available cpukit multilibs?
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
