Mission function - rtems_filesystem_default_fpathconf
Wendell Silva silvawp at gmail.com
Sat Feb 11 16:54:12 UTC 2012
Now I figure out that  rtems_filesystem_default_fpathconf is no longer
available.
I deleted the reference for it in libbbsp/shared/umon/tfsDriver.c and the
compilation worked.
I've just uploaded and documented a patch at bugzilla.rtems.org.
Thanks.
Wendell
2012/2/11 Wendell Silva <silvawp at gmail.com>
> Hi,
> I compiled RTEMS (git master - 4.10.99.0) for arm/csb337 with
> ENABLE_UMON=1 and ENABLE_UMON_CONSOLE=1.
> And, seems that rtems_filesystem_default_fpathconf has been vanish from
> the RTEMS land.
> Is there any substitute for this function?
> Error description:
> arm-rtems4.10-gcc --pipe -B../../../../../.././lib/
> -B../../../../../.././csb637/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
>   -isystem ../../../../../.././csb637/lib/include
> -mstructure-size-boundary=8 -mcpu=arm920 -mfpu=vfp -mfloat-abi=soft -O2 -g
>  -Wall -Wmissing-prototypes -Wimplicit-function-declaration
> -Wstrict-prototypes -Wnested-externs -MT tfsDriver.o -MD -MP -MF
> .deps/tfsDriver.Tpo -c -o tfsDriver.o `test -f
> '../../shared/umon/tfsDriver.c' || echo
> '/home/developer/rtems/git/rtems/c/src/lib/libbsp/arm/csb337/'`../../shared/umon/tfsDriver.c
> /home/developer/rtems/git/rtems/c/src/lib/libbsp/arm/csb337/../../shared/umon/tfsDriver.c:734:
> error: 'rtems_filesystem_default_fpathconf' undeclared here (not in a
> function)
URL: <http://lists.rtems.org/pipermail/users/attachments/20120211/bb59258a/attachment-0001.html>
