Status of ARM/CSB337 bsp
Sat Feb 11 20:40:38 UTC 2012
Hello,
I changed the linker command files of nearly all ARM BSPs and the
interrupt support.  Also the console driver API changed in the
meantime.  It would be nice if you can review the changes since 4.9 or
use a Debugger and step through the system initialization and interrupt
process.  You should also check the memory map of your executable.
On 11/02/12 19:13, Wendell Silva wrote:
> Hello,
> Can anyone confirm if ticker.exe can successfully run on CSB337 BSP - RTEMS
> master/head?
> It was working on the real hardware some time ago:
>   - year 2009
>   - RTEMS version: 4.9.99.0
>   - Kit csb637
>   - bootloader: MicroMonitor (umon) 1.16.8
> In my environment, RTEMS samples built on 4.9.99.0 can run on the real
> hardware, but after 4.10.0 it does not work: it simply reboots silently
> after 5 or 7 seconds.
> Any information on that will be appreciated.
> Wendell Silva
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
