RTEMS tool-chain | nm | strange behavior
Wendell Silva silvawp at gmail.com
Thu Feb 16 23:24:41 UTC 2012
Yes, it does happen on GNU/Linux also.
For example, when I ran the regular nm command on the same bootable RTEMS
image I got the same pattern.
I'll try create a small test case tomorrow.
--wendelll
2012/2/16 Joel Sherrill <joel.sherrill at oarcorp.com>
> If you can produce a small test case, then I can pass it along to the
> binutils group to track .
> Does this happen on GNU/Linux? That would help get attention :)
> --joel
> On 02/16/2012 01:09 PM, Wendell Silva wrote:
> On more thing: sparc-rtems4.10-nm does not exhibit incorrect behavior. So,
> chances are that the bug is limited to i386-rtems tool-chain.
> Wendell.
> 2012/2/16 Wendell Silva <silvawp at gmail.com>
>> Hello everybody,
>>  When calling:
>>  i386-rtems-4.10-nm  --print-size --numeric-sort --line-numbers
>> rtems-img.exe > rtems-img.num
>>  the list of symbols in the file rtems-img.num produces valid line
>> numbers (location of the symbol in the source code) only for those at .text
>> section.
>> When the symbol is in .data (or .bss) it seems to be printed as it was in
>> the location of the last symbol in the .text section, instead of the
>> correct file/line number.
>>  Example of listing:
>>  (... suppressed lines ...)
>> 001283f4 00000109 T lseek
>> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/lseek.c:28
>> 00128500 00000027 T _lseek_r
>> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/lseek.c:98
>> 00128528 00000012 T _malloc_r
>> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/_malloc_r.c:26
>> 0012853c 00000018 T _realloc_r
>> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/_realloc_r.c:27
>> 00128554 0000001e T _write_r
>> /home/developer/rtems-testing/rtems/build-i386-pc386-rtems/i386-rtems4.10/c/pc386/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/write_r.c:37
>> 00128574 0000000c T isatty
>> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/isatty.c:8
>> 00128580 0000004f T _isatty
>> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/_isatty.c:10
>> 001285d0 t __do_global_ctors_aux
>> /builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.5/build/i386-rtems4.10/newlib/libc/posix/../../../../../gcc-4.4.5/newlib/libc/posix/_isatty.c:21
>> 00128600 T __start_set_sysctl_set
>> 00128600 A __stop_set_sysctl_set
>> 00128600 T _init
>> 0012860d T _fini
>> 00128a04 00000018 R rtems_filesystem_table
>> 00128a1c 00000010 R configuration_mount_table
>> 00128a2c 00000004 R rtems_filesystem_mount_table_size
>>  The last three lines are incorrect.
>> Look at "rtems_filesystem_table", for instance. It is expected to be
>> allocated in the source that defines CONFIGURE_INIT, since it is in
>> confdefs.h, however 'nm' thinks it is in _isatty.c, line 21 (!!!!).
>>  Can anyone confirm this strange behavior?
>>  Versions of nm and gcc I'm using:
>> i386-rtems4.10-nm --version
>>  GNU nm (GNU Binutils) 2.20.1
>> Copyright 2009 Free Software Foundation, Inc.
>> This program is free software; you may redistribute it under the terms of
>> the GNU General Public License version 3 or (at your option) any later
>> version.
>> This program has absolutely no warranty.
>>  i386-rtems4.10-gcc --version
>> i386-rtems4.10-gcc (GCC) 4.4.5 20101001 (RTEMS
>> gcc-4.4.5-4.fc14/newlib-1.18.0-19.fc14)
>> Copyright (C) 2010 Free Software Foundation, Inc.
>> This is free software; see the source for copying conditions.  There is NO
>> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>> PURPOSE.
>>  Thanks in advance,
>> Att.
>> Wendell Silva
> Att.
> Wendell P. Silva
> +55 12 8114-8018
> Joel Sherrill, Ph.D.             Director of Research&  Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
>     Support Available             (256) 722-9985
Att.
Wendell P. Silva
+55 12 8114-8018
URL: <http://lists.rtems.org/pipermail/users/attachments/20120216/1bc90396/attachment-0001.html>
