Problem with autoconf for 4.11 in the MinGW
Ralf Corsepius ralf.corsepius at rtems.org
Fri Feb 17 06:10:59 UTC 2012
On 02/17/2012 06:06 AM, Andrei Chichak wrote:
> Hi all,
> I am getting the tools into shape to attempt to compile 4.11.
> I got the various bz2 files from Chris,
The official packages can be found under
ftp://ftp.rtems.org/pub/rtems/mingw32/
> untarred them into place,
You need to untar them into '/'
They are not relocatible (can not be moved around).
> then started using my standard build routine.
> ./bootstrap -c
> then
> $ ./bootstrap
> ./c
> Can't locate Autom4te/ChannelDefs.pm in @INC (@INC contains: /opt/rtems-4.11/share/autoconf /usr/lib/perl5/5.6.1/msys /usr/lib/perl5/5.6.1 /usr/lib/perl5/site_perl/5.6.1/msys /usr/lib/perl5/site_perl/5.6.1 /usr/lib/perl5/site_perl .) at /c/opt/rtems-4.11/bin/autoreconf line 40.
Here, perl is complaining about not being able to find autoconf's perl
modules.
> It looks like autoconf either is missing a file or there is more to the install process than a simple tar.
> Any hints?
Just a wild guess:
In the error message above /c/opt/rtems-4.11/bin/autoreconf
is looking for "Autom4te/ChannelDefs.pm" in @INC. with @INC not
containing /c/opt/rtems-4.11/share/autoconf.
i.e. you are invoking the tool with drive letter-prefixed directories,
while the tools are configured to be used without drive letters.
Ralf
