RTEMS and video support
Kirchner, Ralf rkirchner at tycoint.com
Tue Feb 21 08:19:14 UTC 2012
Hi Indy,
If you ever solve the problem with the missing X11 support for using nxlib to build fltk, could you please let me know?
Currently I am working on other application problems but earlier or later (rather later) I will have to look into a GUI for RTEMS applications.
Kind regards
        Ralf
From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] On Behalf Of Inderjit Singh
Sent: Monday, February 20, 2012 11:50 AM
To: Gedare Bloom
Cc: rtems-users at rtems.org
Subject: Re: RTEMS and video support
Thanks Gedare.
I already checked that and the paragraph below tells me that there is no support really:
"The following packages are included but not currently ported:"
• mmap_kit - our own invention to provide things needed by svgalib before these are merged into RTEM
• svgalib - (1.4.3)
• fltk - (1.1.10)
We need nxlib from Microwindows to build fltk. This will require us creating a small kit of X11 .h files and fonts so nxlib will build and run. Then fltk should just build and work."
Regards,
Indy
________________________________________
To: "Inderjit Singh" <inderjit.singh at spaceapplications.com>
Sent: Saturday, 18 February, 2012 5:23:28 AM
Hi,
I'm not personally familiar, but I think the Graphics Toolkit [1] had
some work that applies to video, and I think the Milkymist folks have
done some work with a framebuffer but I don't know the details. There
is some framebuffer support under cpukit/libmisc/fb
Good luck!
Gedare
[1] http://www.rtems.com/wiki/index.php/RTEMSGraphicsToolkit
On Fri, Feb 17, 2012 at 4:46 AM, Inderjit Singh
<inderjit.singh at spaceapplications.com> wrote:
> Hi,
> I have a general question regarding video support in RTEMS.
> Is there any? I'd like to use a graphical display to put some elements on a
> screen uisin DVI/VGA interface. Is there perhaps a framebuffer driver
> available?
> Thanks,
> Inderjit
> Inderjit Singh
> Software Engineer
> Avionics & Embedded Systems
> Email: inderjit.singh at spaceapplications.com
> Space Applications Services
> Leuvensesteenweg 325
> B-1932 Zaventem
> Belgium
> Direct Tel: +32-(0)2-416.05.27
> Fax: +32 (0)2-721.54.44
> Please consider the environment before printing this email
> rtems-users mailing list
