Some LPC17xx code fragments
Pavel Pisa
ppisa4lists at pikron.com
Wed Feb 22 09:50:27 UTC 2012
Hello Sebastian,
On Tuesday 21 February 2012 14:03:24 Sebastian Huber wrote:
> thanks for your links. Is the USB support for device, host, or OTG?
our code is device only. We use if for some our (vendor
specific) profiles (USB<->CAN converter, USB<->uLAN RS485)
and it has been used for standard compliant HID profile
devices as well.
I have even some partial port of the code for RTEMS
for i.MX1 system.
Best wishes,
Pavel
> On 02/17/2012 03:12 PM, Pavel Pisa wrote:
> > Hello Sebastian,
> > I have noticed your work on LPC17xx taget.
> > May it be, that some fragments for our code could be reused.
> > Our "sysless" set of the libraries provide support
> > of more peripherals when MCUs are used without operating
> > system and may it be, that some code can be reused for RTEMS.
> > http://ulan.git.sourceforge.net/git/gitweb.cgi?p=ulan/sysless
> > LPC17xx core routines are there
> > http://ulan.git.sourceforge.net/git/gitweb.cgi?p=ulan/sysless;a=tree;f=ar
> >ch/arm/mach-lpc17xx
> > USB
> > http://ulan.git.sourceforge.net/git/gitweb.cgi?p=ulan/sysless;a=tree;f=li
> >bs4c/usb
> > SPI
> >bs4c/spi
> > I2C
> >bs4c/i2c
> > Integration code
> > http://ulan.git.sourceforge.net/git/gitweb.cgi?p=ulan/sysless;a=tree;f=bo
> >ard/arm/lpc17xx-common
> > The whole tree is meant to be freely available under GPL/MPL for any kind
> > of use and I would provide confirmation/change for explicit re-license to
> > RTEMS GPL+exception where code is directly originating from me or my
> > colleagues.
> > Best wishes,
> > Pavel
