RTEMS on x86 PC
Cláudio Silva claudiodcsilva at gmail.com
Wed Feb 22 11:33:18 UTC 2012
Hi,
Yes you can test RTEMS in your PC. You just have to build RTEMS for
the i386 architecture and pc386 (or later) board support package. Once
you have a RTEMS application built you can use GRUB to boot it. (if
you have grub already installed on your PC you just have to change the
"kernel=" parameter to point to an RTEMS application)
For more information on how to build RTEMS and a sample application:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/
http://wiki.rtems.org/wiki/index.php/Quick_Start
http://wiki.rtems.org/wiki/index.php/Example_Application_Compiling
For more information about the boot:
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/i386/pc386/HOWTO
http://wiki.rtems.org/wiki/index.php/Pc386
http://wiki.rtems.org/wiki/index.php/QEMU
Cláudio
On Wed, Feb 22, 2012 at 11:03 AM, harryxiyou <harryxiyou at gmail.com> wrote:
> On Wed, Feb 22, 2012 at 3:58 PM, Fered <a_fered at yahoo.com> wrote:
>> Hi,
> Hi there,
>> I'm newbie and want to test RTEMS on my PC.(on real hardware)
>> Is it possible?
> I think it is ok for us to test on our PC. I am now searching the way, too.
> I recommend some useful links for you. If you find the way tell me please.
> [0] http://wiki.rtems.org
> [1] http://www.rtems.org/
> [2] http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> [3] http://git.rtems.org/
> Thanks
> Harry Wei
> rtems-users mailing list
> rtems-users at rtems.org
