Motorola Shared BSPs not Linking
Ralf Corsepius ralf.corsepius at rtems.org
Thu Feb 23 14:17:25 UTC 2012
On 02/22/2012 05:54 PM, Joel Sherrill wrote:
> Hi
> Just came across this in the build logs and unfortunately
> don't have time to investigate. This was on the mcp750
> but every motorola_shared variant fails the same way.
> powerpc-rtems4.11-objcopy -O binary -R .comment -S hello.exe rtems
> gzip -vf9 rtems
> rtems: 55.1% -- replaced with rtems.gz
> powerpc-rtems4.11-ld -o hello.ralf
> ../../../../../mcp750/lib/bootloader.o --just-symbols=hello.exe -b
> binary rtems.gz -T ../../../../../mcp750/lib/ppcboot.lds -Map hello.map
> && chmod 755 hello.exe
> ../../../../../mcp750/lib/ppcboot.lds:97: undefined symbol
> `__rtems_start' referenced in expression
I can reproduce this.
> Anyone have any ideas or fixes?
The only place in rtems.git which provides a symbol named __rtems_start
is c/src/lib/libbsp/powerpc/shared/start/vectors_entry.S
However, this file doesn't seem to be referenced by the mcp750 BSP nor
by the motorola_powerpc:
# grep -R shared/start/vectors_entry.S
c/src/lib/libbsp/powerpc/*/Makefile.am
c/src/lib/libbsp/powerpc/beatnik/Makefile.am:EXTRA_DIST +=
../../powerpc/shared/start/vectors_entry.S
c/src/lib/libbsp/powerpc/beatnik/Makefile.am:vectors_entry.$(OBJEXT):
c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am:libbspstart_a_SOURCES
+= ../../powerpc/shared/start/vectors_entry.S
c/src/lib/libbsp/powerpc/mvme3100/Makefile.am:EXTRA_DIST +=
../shared/start/vectors_entry.S
c/src/lib/libbsp/powerpc/mvme3100/Makefile.am:vectors_entry.$(OBJEXT):
c/src/lib/libbsp/powerpc/mvme5500/Makefile.am:
Seems to me, as if some of the powerpc exception/irq "generalizations"
broke something.
I am not sufficiently familiar with how this is supposed to work to be
able to provide a fix.
Ralf
