Space Qualified RTEMS
Rolf Schroedter rolf.schroedter at dlr.de
Fri Jan 27 07:17:46 UTC 2012
This is mainly two patches. Both are problems with the Leon port, not
the RTEMS itself.
1. LEON startup code overwrites RTEMS system configuration under some
circumstances:
http://tech.groups.yahoo.com/group/leon_sparc/message/18124
2. RTEMS - rtems_clock_get_uptime() fails during timer tick:
http://www.rtems.org/ml/rtems-users/2011/february/msg00093.html
Both problems have been discussed last year with Konrad Eisele, but my
patches are still not included in the current Gaisler release.
(I checked the latest
ftp://gaisler.com/gaisler.com/rcc/src/rtems-4.10-1.2.0-src.tar.bz2 dated
11/2011).
AFAIK the patch for problem 2. has been included into the current RTEMS
branch by Joel Sherrill.
@Phil: If you need these patches, I can send them to you by eMail.
Regards,
Rolf.
On 26.01.2012 16:46, Phil Smith wrote:
> On Wed, Jan 25, 2012 at 01:01:30PM +0100, Rolf Schroedter wrote:
>> Until today, nobody from ESA complained about that I'm using the
>> RTEMS-4.10 branch, provided by Aeroflex-Gaisler
>> http://www.gaisler.com. This is a bit behind the actual versions
>> from rtems.org. I'm using it with 2-3 (non-critical) bug-fixes and
> Hi Lee and all,
> We are using the latest Aeroflex-Gaisler RTEMS too on the Solar Orbiter EUI
> instrument and will keep open the option of an upgrade/patch or two during
> development if necessary.  It will be interesting to see what the other
> instruments choose.
> We like 4.10 or later for the same reasons expressed by others: bugfixes,
> features and support together with better testing.  RFS too.
> Rolf, what bug-fixes did you find necessary? Are they just selected official
> patches from 4.10 to latest?
> Phil.
