stack_checker_report_usage and cpu_usage_report to array
Eduardo Esteban
eaestebanb at gmail.com
Fri Jan 27 10:12:21 UTC 2012
Hello Alan,
Could you please provide me an example of the use of rtems_shell_script
because I was not able to find it.
Best regards,
Eddie
On 26 January 2012 19:49, Cudmore, Alan P. (GSFC-5820) <
alan.p.cudmore at nasa.gov> wrote:
> We use the rtems_shell_script API to execute a single shell command and
> store the results in a file. We then downlink the file with the results.
> It should work with all of the commands.
> Alan
> On Jan 26, 2012, at 1:17 PM, Phil Smith wrote:
> > We're using RTEMS for ESA's Solar Orbiter and one change we need and
> would be
> > useful in general for space missions is to send the output of
> > rtems_stack_checker_report_usage
> > and
> > rtems_cpu_usage_report
> > to an array/structure instead of to printk so that the results can be
> part of
> > regular telemetry.
> > We could use rtems_stack_checker_report_usage_with_plugin and
> > rtems_cpu_usage_report_with_plugin and have the plugin be a function to
> > intercept the text and extract it ... however it would save precious
> (space
> > qualified) memory to just edit the RTEMS code.
> > Is anyone else interested in this or done it already?
> > Philip J. Smith __o Dept. of Space and Climate Physics,
> > pjs1 at mssl.ucl.ac.uk _'\<; Mullard Space Science Laboratory,
> > ((( (*)/(*) University College London.
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120127/d9d1e5c8/attachment.html>
