Permission for folder created during rtems_fsmount
Sebastian Huber
Tue Jan 17 09:16:20 UTC 2012
The default umask is 022. This corresponds perfectly to the permissions below
"/mnt" and "ram". Please have a look at
http://pubs.opengroup.org/onlinepubs/009695399/functions/umask.html
How do you create the "flash" directory?
On 01/17/2012 10:02 AM, ali nasir wrote:
> Hi,
> Below is the permissions of the '/mnt' and 'ram' for RTEMS4.10
> # ls -l
> total 0
> drwxr-xr-x 1 root root 2992 Jan 1 1988 dev
> drwxr-xr-x 1 root root 1088 Jan 17 12:09 etc
> drwxr-xr-x 1 root root 544 Jan 17 12:09 mnt
> # cd mnt
> [/mnt] # ls -l
> total 1
> drwx--x--x 0 root root 512 Nov 22 14:01 flash
> drwxr-xr-x 1 root root 272 Jan 17 12:09 ram
> [/mnt] #
> Is it that because the /mnt does not have 'w' set for group and other, the 'ram' also does not have 'w' for group and others? How do i give 'w' rights to all (apart from using chmod after mounting the ram)? I now see that flash does not even have 'r' for the group and others.
> Regards,
> Ali
> On Tue, Jan 17, 2012 1:51 PM IST Sebastian Huber wrote:
>> On 01/17/2012 09:01 AM, ali nasir wrote:
>>> Hi,
>>> We observed a change in the permissions of folders created during rtems_fsmount between the RTEMS4.9 and RTEMS4.10.
>>> When we mount the ramdisk on the 4.9 on path /mnt/ram, this directory has rwx permissions for all. But with the 4.10 the rwx permissions are only granted to the root. We use the RFS on the ramdisk.
>>> We see that a build function is introduced in the 4.10 and it plays with the permissions before calling the mknod function. Is the above behavior the desired behavior or it is a problem? What do we do so that the rwx permissions are given to everyone? We know that calling chmod just after mounting will solve this. But is there another way out?
>> Which permissions do the "/mnt" and "ram" have? Please have a look at
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone : +49 89 18 90 80 79-6
>> Fax : +49 89 18 90 80 79-9
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
