[GSoC] Arm Simulators problem.
Tue Jul 3 19:56:01 UTC 2012
On 07/03/2012 04:56 AM, Hesham Moustafa wrote:
> Hi,
> When i run hello.exe sample with gdb or any simulator ( whether at
> rtems-testing/sim-script or not ),
> The program output that and i got nothing.
> hesham at Hesham-Laptop sim-scripts$ qemu-gumstix
> /home/hesham/gumstix/arm-rtems4.11/c/gumstix/testsuites/samples/hello/hello.exe
> qemu-system-arm is /usr/bin/qemu-system-arm
> running
> for maximum 60 seconds...
> Other simulators outputs connection time out.
> Note that i have enables test when configuring rtems for building with
> --enable-tests.
> I have build the following BSPs for ARM and test hello.exe with gdb
> and simulator and i got the same result.
Each takes a unique set of arguments to run with a simulator.
> edb7312
> csb337
Skyeye only. Not on qemu AFAIK
> gumstix
Qemu from my experience. Likely supported on skyeye. Don't know though.
> lm3s69xx
Patch qemu based on Sebastian's comments.
Joel Sherrill, Ph.D.             Director of Research&   Development
