Developing under MacOS
Binkowski, Cassio
cassioiks at gmail.com
Sun Jul 15 18:08:38 UTC 2012
Hi Eric
Thanks a lot. That's gonna do it, I guess.
I tried to run the script but all I got was the following:
./getAndBuildTools-4.11.sh
: command not found4.11.sh: line 2:
: command not found4.11.sh: line 6:
: command not found4.11.sh: line 12:
: command not found4.11.sh: line 26:
: command not found4.11.sh: line 31:
: command not found4.11.sh: line 44:
: command not found4.11.sh: line 51:
': not a valid identifierh: line 56: export: `MAKE
': not a valid identifierh: line 58: export: `SHELL
: command not found4.11.sh: line 59:
'/getAndBuildTools-4.11.sh: line 66: syntax error near unexpected token `{
'/getAndBuildTools-4.11.sh: line 66: `getSource() {
Do you know what it is?
Also, I does this script download all BSP tools already?
Thanks a lot for making this Script.
Best regards
Cassio
On Sat, Jul 14, 2012 at 2:21 PM, Eric Norum <wenorum at lbl.gov> wrote:
> Yep.
> I've attached my 'get and build' script.
> Please let me know if this works for you.
> On Jul 14, 2012, at 9:31 AM, Binkowski, Cassio wrote:
> > Hi everyone
> > Has anyone had the experience of developing RTEMS application using
> MacOS platform?
> > I would like to know if it`s worth the time it takes to build all tools
> from source instead of just using the VM.
> > Thanks and best regards
> > Cassio
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120715/5c9ef43d/attachment.html>
