Virtualbox RTEMS Setup
Aric Hunter aricahunter at gmail.com
Thu Jul 19 16:02:41 UTC 2012
Hello,
I am attempting to get the RTEMS development station setup on the Centos
virtualbox.
I was following the instructions on the wiki:
http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
I got to the section for testing the i386/pc386 without any problems, but
then I tried to do tho the following command:
        pc386 -i
./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
and got this error:
        /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line 298:
type: qemu: not found
        FAILED:  Path appears to be broken (cannot find qemu)
Any ideas as to what I am missing/doing incorrectly?
My ultimate goal is to run lm3s6965 instead of pc386, but I get the same
error with either.
Thanks,
Aric Hunter
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/13f1fc61/attachment.html>
