Virtualbox RTEMS Setup
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jul 19 16:27:36 UTC 2012
On 07/19/2012 11:25 AM, Aric Hunter wrote:
> I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
> I haven't tried solution 2.
> So, for solution 2, somewhere in the pc386 script it attempts to run
> qemu but it should be qemu-system-i386?
Yep.
You could update the rtems-testing git module and type make :)
ls /home/rtems/qemu/install/bin and see what's there
> I will look for that.
> Thanks for the amazingly quick replies,
> Aric Hunter
> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> Hi
> I know this has been answered before but I don't recall which
> answer it is:
> (1) qemu is not in your PATH. The qemu installation was
> left out of setting the PATH in the setenv script
> (2) It is really called qemu-system-i386 and the script
> needs to use the correct name. qemu renamed this.
> -joel
> On 07/19/2012 11:02 AM, Aric Hunter wrote:
> Hello,
> I am attempting to get the RTEMS development station setup on
> the Centos virtualbox.
> I was following the instructions on the wiki:
> http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
> I got to the section for testing the i386/pc386 without any
> problems, but then I tried to do tho the following command:
> pc386 -i
> ./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello/hello.exe
> and got this error:
> /home/rtems/rtems-4.11-work/rtems-testing/bin/pc386:
> line 298: type: qemu: not found
> FAILED: Path appears to be broken (cannot find qemu)
> Any ideas as to what I am missing/doing incorrectly?
> My ultimate goal is to run lm3s6965 instead of pc386, but I
> get the same error with either.
> Thanks,
> Aric Hunter
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/68727abc/attachment.html>
