Virtualbox RTEMS Setup
Steven Grunza sgrunza at ctdi.com
Fri Jul 20 13:31:38 UTC 2012
See replies in-line
> -----Original Message-----
> From: Aric Hunter [mailto:aricahunter at gmail.com]
> Sent: Thursday, July 19, 2012 6:28 PM
> To: Steven Grunza
> Cc: rtems-users at rtems.org
> Subject: Re: Virtualbox RTEMS Setup
> does the configure file run those patches (I've never used a patch
> file)?
No.  It's a manual operation.  Typically I use a command sequence such
as the following:
{Acquire the correct version source files}
git clone git://git.qemu.org/qemu.git qemu.git
cd qemu.git
cat 0001-target-arm-Fixed-ARMv7-M-SHPR-access.patch | patch -p1
The problem is getting the correct version source files.  The qemu
project was at version 1.0.50 when the patches were created.  I was able
to use version 1.0.90.  QEMU now appears to be at version 1.1.50 and the
patches do not apply properly.  Perhaps they are no longer needed?
> and what example did you use? I don't see any test files
> (hello.exe) in the b-lm3s6965 branch.
I used the example applications for RTEMS.  These are sample
applications that (as far as I know) work with any version of RTEMS.  I
got them by doing the following:
git clone git://git.rtems.org/examples-v2.git examples-v2.git
cd examples-v2.git/hello/hello_world_c
export RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/arm-rtemseabi4.11/lm3s6965
make
cd o-optimize
grunzasr at stm32dbg% which qemu-system-arm
/usr/local/bin/qemu-system-arm
grunzasr at stm32dbg% /usr/local/bin/qemu\-system\-arm --version
QEMU emulator version 1.0.90, Copyright (c) 2003-2008 Fabrice Bellard
{Note: This is the patched version of qemu}
grunzasr at stm32dbg% qemu-system-arm -nographic -M lm3s6965evb -kernel
hello.ralf
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
