Virtualbox RTEMS Setup
Fri Jul 20 16:56:35 UTC 2012
maybe this will help: http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
that kind of gives an idea about how to build and "install" RTEMS;
you'll want to substitute arm for sparc, and the ARM's BSP for sis..
Or read the manuals about building rtems:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/started.html
On Fri, Jul 20, 2012 at 12:39 PM, Aric Hunter <aricahunter at gmail.com> wrote:
> Can you go back a step. How did you install arm?
> I have /usr/local/bin/qemu-system-arm
> but I don't have /opt/rtems-4.11/arm-rtemseabi4.11
> I'm sorry that I'm such an rtems noob.
> I'm an intern and I'm pretty good with typical programming, but rtems is
> slightly beyond me. I'm just trying to get an rtems station set up for
> another employee.
> On Fri, Jul 20, 2012 at 6:31 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
>> See replies in-line
>> > -----Original Message-----
>> > From: Aric Hunter [mailto:aricahunter at gmail.com]
>> > Sent: Thursday, July 19, 2012 6:28 PM
>> > To: Steven Grunza
>> > Cc: rtems-users at rtems.org
>> > Subject: Re: Virtualbox RTEMS Setup
>> > does the configure file run those patches (I've never used a patch
>> > file)?
>> No.  It's a manual operation.  Typically I use a command sequence such
>> as the following:
>> {Acquire the correct version source files}
>> git clone git://git.qemu.org/qemu.git qemu.git
>> cd qemu.git
>> cat 0001-target-arm-Fixed-ARMv7-M-SHPR-access.patch | patch -p1
>> The problem is getting the correct version source files.  The qemu
>> project was at version 1.0.50 when the patches were created.  I was able
>> to use version 1.0.90.  QEMU now appears to be at version 1.1.50 and the
>> patches do not apply properly.  Perhaps they are no longer needed?
>> > and what example did you use? I don't see any test files
>> > (hello.exe) in the b-lm3s6965 branch.
>> I used the example applications for RTEMS.  These are sample
>> applications that (as far as I know) work with any version of RTEMS.  I
>> got them by doing the following:
>> git clone git://git.rtems.org/examples-v2.git examples-v2.git
>> cd examples-v2.git/hello/hello_world_c
>> export RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/arm-rtemseabi4.11/lm3s6965
>> make
>> cd o-optimize
>> grunzasr at stm32dbg% which qemu-system-arm
>> grunzasr at stm32dbg% /usr/local/bin/qemu\-system\-arm --version
>> QEMU emulator version 1.0.90, Copyright (c) 2003-2008 Fabrice Bellard
>> {Note: This is the patched version of qemu}
>> grunzasr at stm32dbg% qemu-system-arm -nographic -M lm3s6965evb -kernel
>> hello.ralf
>> *** HELLO WORLD TEST ***
>> Hello World
>> *** END OF HELLO WORLD TEST ***
> rtems-users mailing list
