write data to the address (PC104)--solved
zhoupeng
zpeng563 at 126.com
Sun Jul 1 08:26:05 UTC 2012
Recently , I want to write data to register of can device. At first I use IO space , so I can't make the device operated. Later, I change to use memory space. I can send data and receive data from the register.
IO space:
两个最基本的SJA1000寄存器读写函数
/*unsigned char read_sja(unsigned char RegNum)
unsigned char bValue;
RegNum &= 0x7F; //最高位清0
inport_byte(BASE_ADDRESS+RegNum,bValue);
return (bValue);
void write_sja(unsigned char RegNum, unsigned char bValue)
outport_byte(BASE_ADDRESS+RegNum,bValue);
delay(50000);
memory space:
unsigned char data;
RegNum &= 0x7F;
data = * (volatile unsigned char *)((BASE_ADDRESS)+RegNum);
return (data);
void write_sja(unsigned char RegNum, unsigned char data)
RegNum &= 0x7F;
* (volatile unsigned char *)((BASE_ADDRESS)+RegNum) = data;
By the way , not all the PC-104 have can module. If you PC-104 have can module, you can follow the manual. But you must find out if the operation of register is IO space or memory space.
URL: <http://lists.rtems.org/pipermail/users/attachments/20120701/cde69d41/attachment-0001.html>
