Memory management between threads in RTEMS
m.shahverdi sspardis2 at gmail.com
Wed Jul 18 15:58:11 UTC 2012
This is my application that is written in C,I write the main code till now.
this app is an elevator that goes up and down in a 4 floors building:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#include<stdbool.h>
#include<time.h>
#include <sys/time.h>
#include <sys/types.h>
#include <unistd.h>
#include <signal.h>
void handler(int signo)
  return;
typedef struct person prs;
int elevator_run();
struct person
    int place;
    int distination;
    char direction;
    bool inout;// in:true,out:false
    bool exit;//if person exits true
    prs * next;
int stage[5];///////to know stop in which level
int up_down;///////to know direct  1 for up 0 for down  2 for none
int stop_move;/////to know if elevator is stop or no stop 0 move 1
int current_place;
int distination;
time_t base;
int xx;
int main()
    int place;
    int direct;
    int counter_in=0;
    int counter_out=0;
    int in_out;////in=1;out=0
    int dis;///to get distination of person in elevator
    prs* headin;
    prs* headout;
    prs*newnode;
    prs*nextnode;
    prs*node;
    headin=(prs*)malloc(sizeof(prs));
    headout=(prs*)malloc(sizeof(prs));
    pthread_t thread_id;
        pthread_create(&thread_id, NULL,  elevator_run, NULL);
          struct sigaction sa;
  sa.sa_handler = handler;
  sigemptyset(&sa.sa_mask);
  sa.sa_flags = 0;
  sigaction(SIGALRM, &sa, NULL);
    if(headin==NULL)
        printf("\nError in memory allocation!\n ");
        return 1;
    if(headout==NULL)
        return 1;
    int update;
    printf("This is elevator stopped at ground \n tell us your place and
distination ");
    while(1)
        update=0;
        alarm(1);
  if (scanf("%d", &in_out) == 1)
    alarm(0); // cancel the alarm
  else
    continue;
         //   scanf("% d", & in_out);
        if (in_out==1)
          scanf("%d",& dis);
              if(current_place==distination)
              update=1;
              distination=dis;
              else if((up_down==1 && distination<dis) ||(up_down==0 &&
distination>dis))
                  update=1;
                  stage[distination]=1;
                distination=dis;
              else if((up_down==1 && current_place<dis<distination)
||(up_down==0 && distination<dis<current_place))
                       stage[dis]=1;
                    else
                       newnode=(prs*)malloc(sizeof(prs));
                       if(newnode==NULL)
                        return 1;
                       counter_in++;
                       newnode->exit=false;
                       newnode->distination=dis;
                          newnode->next=headin->next;
                          headin->next=newnode;
         else {
            scanf("%d %d",& place,& direct);
            if(direct=='q')
            return 1;
        if(stop_move==0){
          distination = place;
          printf("/////");}
          else {
        if(direct==up_down &&((up_down==1&&
current_place<=place<=distination) ||(up_down==0&&
current_place>=place>=distination)))
           stage[place]=1;
        if(direct==up_down && ((up_down==1 && place > distination) ||
(up_down==0 && place < distination)))
               distination=place;
               update=1;
        else
           if(newnode==NULL)
            return 1;
           counter_out++;
           newnode->place=place;
int elevator_run()
   time_t current;
   int i;
   int y=0;
   //float x=1;
   for(i=0;i<5;i++)
   stage[i]=0;
   up_down=1;
   stop_move=0;/////to know if elevator is stop or no
   current_place=0;
   distination=0;
   while(1)
      if(stop_move==1)
        if(up_down==1)
      current=time(NULL);
      if(current==base + 5)
      base=current;
      y=y+1;
    //  printf("y = %f" ,y);
    else
     current=time(NULL);
      base=current;
      y=y-1;
    if(stop_move==0 && distination > current_place)
        stop_move=1;
        base=time(NULL);
        up_down=1;
        printf("salam");
    if(stop_move==0 && distination < current_place)
        stop_move=1;
        base=time(NULL);
        up_down=0;
      if(y == 0) {current_place=0;if(distination==0) stop_move=0;}
      if(y == 1 && current_place !=1) { printf("place1"); current_place=1;
if(distination==1) stop_move=0;}
      if(y == 2 && current_place != 2)
{current_place=2;printf("place2");if(distination==2) stop_move=0;}
      if(y == 3 && current_place != 3)
{current_place=3;printf("place3");if(distination==3) stop_move=0;}
      if(y == 4 && current_place != 4)
{current_place=4;printf("place4");if(distination==4) stop_move=0;}
On Wed, Jul 18, 2012 at 8:11 PM, Till Straumann
<strauman at slac.stanford.edu>wrote:
>  Maybe you could share some example code so that we understand
> what exactly you're trying to do?
> T.
> On 07/18/2012 10:37 AM, m.shahverdi wrote:
> These two threads have some common fields that I use mutex on these fields
> but in general I read in c_user document of RTEMS that this OS has a flat
> memory and I'm worry about unsafe access to memory that each thread
> allocate in the beginning of execution.
> On Wed, Jul 18, 2012 at 7:42 PM, Thomas Doerfler <
> Thomas.Doerfler at embedded-brains.de> wrote:
>> Hi,
>> funny topic: one question, many different answers, none of them is
>> wrong ;-)
>> Maybe you can specify, what you expect from a "memory protection"
>> mechanism:
>> - A way to synchronize two threads, so only one is allowed to
>> access/write to a memory area?
>> - A way to detect, when a thread inadvertedly tries to access/write to
>> another thread's private area?
>> - Something different?
>> wkr,
>> Thomas.
>> Am 18.07.2012 16:20, schrieb m.shahverdi:
>>  > Hi, I have an application with two threads but I don't know how to
>> > protect memory of each thread against other thread.please help me.
>> > thanks
>>  > _______________________________________________ rtems-users mailing
>> > list rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
>>  IMD Ingenieurbuero fuer Microcomputertechnik
>> Thomas Doerfler           Herbststrasse 8
>> D-82178 Puchheim          Germany
>> email:    Thomas.Doerfler at imd-systems.de
>> PGP public key available on request
>> embedded brains GmbH
>> Thomas Doerfler
>> Obere Lagerstrasse 30
>> D-82178 Puchheim
>> Germany
>> email: Thomas.Doerfler at embedded-brains.de
>> Phone: +49-89-18908079-2
>> Fax: +49-89-18908079-9
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-users mailing list
> به "هوالحی" زنده می کند؛
> آنسان که می میراند به "هوالممیت"..
> ما را به "هوالشهید" است که مدام می میراند و زنده می کند..
URL: <http://lists.rtems.org/pipermail/users/attachments/20120718/d89a0036/attachment-0001.html>
