Virtualbox RTEMS Setup
Aric Hunter
aricahunter at gmail.com
Thu Jul 19 16:25:26 UTC 2012
I tried solution 1) already (PATH=$PATH:/home/rtems/qemu/install/bin)
I haven't tried solution 2.
So, for solution 2, somewhere in the pc386 script it attempts to run qemu
but it should be qemu-system-i386?
I will look for that.
Thanks for the amazingly quick replies,
Aric Hunter
On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> Hi
> I know this has been answered before but I don't recall which
> answer it is:
> (1) qemu is not in your PATH. The qemu installation was
> left out of setting the PATH in the setenv script
> (2) It is really called qemu-system-i386 and the script
> needs to use the correct name. qemu renamed this.
> -joel
> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>> Hello,
>> I am attempting to get the RTEMS development station setup on the Centos
>> virtualbox.
>> I was following the instructions on the wiki:
>> http://www.rtems.com/wiki/**index.php/Virtual_Machines_**
>> for_RTEMS_Development<http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development>
>> I got to the section for testing the i386/pc386 without any problems, but
>> then I tried to do tho the following command:
>> pc386 -i ./rtems-4.11-work/b-pc386/**i386-rtems4.11/c/pc386/**
>> testsuites/samples/hello/**hello.exe
>> and got this error:
>> /home/rtems/rtems-4.11-work/**rtems-testing/bin/pc386: line 298:
>> type: qemu: not found
>> FAILED: Path appears to be broken (cannot find qemu)
>> Any ideas as to what I am missing/doing incorrectly?
>> My ultimate goal is to run lm3s6965 instead of pc386, but I get the same
>> error with either.
>> Thanks,
>> Aric Hunter
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/da3ab652/attachment-0001.html>
