Virtualbox RTEMS Setup
Steven Grunza
sgrunza at ctdi.com
Thu Jul 19 22:03:54 UTC 2012
The patches I used are in rtems/c/src/lib/libbsp/arm/lm3s69xx/*.patch
Make sure you're not using an ELF file. My understanding is that the
qemu-system-arm requires a binary image of the code to be run, not a
file requiring re-location.
Running the hello example gave me the following:
grunzasr at stm32dbg% qemu-system-arm -nographic -M lm3s6965evb -kernel
hello.ralf
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
qemu: hardware error: gic_dist_writeb: Bad offset 4f0
The hardware error is caused by the BSP not having "a proper board
reset".
The build created the following files:
grunzasr at stm32dbg% ls -l
total 2888
-rwxrwxr-x 1 grunzasr grunzasr 79032 May 8 16:36 hello.bin*
-rwxrwxr-x 1 grunzasr grunzasr 2711472 May 8 16:35 hello.exe*
-rw-rw-r-- 1 grunzasr grunzasr 28045 May 8 16:35 hello.num
-rwxrwxr-x 1 grunzasr grunzasr 79032 May 8 16:35 hello.ralf*
-rw-rw-r-- 1 grunzasr grunzasr 37040 May 8 16:35 test.o
grunzasr at stm32dbg% file hello.exe
hello.exe: ELF 32-bit LSB executable, ARM, version 1 (SYSV), statically
linked, not stripped grunzasr at stm32dbg% file hello.ralf
hello.ralf: data
I'm not sure what the .ralf extension is supposed to mean but if you
watch the build you'll see that the .ralf file is the result of running
arm-*-objcopy on the .exe (ELF) file with the binary output option;
therefore, the .ralf file is a binary file.
Steven G
[mailto:rtems-users-bounces at rtems.org] On Behalf Of Aric Hunter
Sent: Thursday, July 19, 2012 5:36 PM
To: rtems-users at rtems.org
Subject: Re: Virtualbox RTEMS Setup
I installed qemu-system-arm and attempted to test the lm3s6965 with a
test file in the pc386 testsuite and got this error.
lm3s6965 -v -i hello.exe
Default program to run is
Using qemu-system-arm
qemu-system-arm is /usr/local/bin/qemu-system-arm
TESTS TO RUN: hello.exe
INTERACTIVE runtest hello.exe single 0
qemu-system-arm -nographic -M lm3s6965evb -kernel hello.exe
qemu: fatal: Bad mode 1c
R00=00000000 R01=0000007f R02=00000000 R03=00000000
R04=00890089 R05=00000000 R06=00000000 R07=00000000
R08=00000000 R09=00000000 R10=00000000 R11=00000000
R12=00000000 R13=464c457f R14=00000000 R15=00010118
PSR=00000173 ---- T svc32
Aborted (core dumped)
what patches are you talking about for lm3s6965?
I see some binpatch files, but not much else.
On Thu, Jul 19, 2012 at 10:28 AM, Gedare Bloom
<gedare at rtems.org> wrote:
On Thu, Jul 19, 2012 at 1:12 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 07/19/2012 12:05 PM, Aric Hunter wrote:
> Fantastic!!!
> I looked into /home/rtems/qemu/install/bin and saw the
qemu-system-i386 file
> that you mentioned, and after the update everything with the
i386/pc386
> works just fine.
> If you have time:
> How do I get qemu-system-arm?
> Is it as simple as another git update?
> On that virtualbox image, the qemu was pulled from their git
> and built. You just need to do their build and let it build
everything.
> I restricted it to i386 for size.
IIRC for lm3sxx there are some patches for qemu in the bsp
directory..
not sure if they are still necessary.
> Thanks oodles,
> Aric Hunter
> On Thu, Jul 19, 2012 at 9:27 AM, Joel Sherrill
> wrote:
>> On 07/19/2012 11:25 AM, Aric Hunter wrote:
>> I tried solution 1) already
(PATH=$PATH:/home/rtems/qemu/install/bin)
>> I haven't tried solution 2.
>> So, for solution 2, somewhere in the pc386 script it attempts
to run qemu
>> but it should be qemu-system-i386?
>> Yep.
>> You could update the rtems-testing git module and type make
>> ls /home/rtems/qemu/install/bin and see what's there
>> I will look for that.
>> Thanks for the amazingly quick replies,
>> Aric Hunter
>> On Thu, Jul 19, 2012 at 9:10 AM, Joel Sherrill
>> wrote:
>>> Hi
>>> I know this has been answered before but I don't recall
which
>>> answer it is:
>>> (1) qemu is not in your PATH. The qemu installation was
>>> left out of setting the PATH in the setenv script
>>> (2) It is really called qemu-system-i386 and the script
>>> needs to use the correct name. qemu renamed this.
>>> -joel
>>> On 07/19/2012 11:02 AM, Aric Hunter wrote:
>>>> Hello,
>>>> I am attempting to get the RTEMS development station setup
on the Centos
>>>> virtualbox.
>>>> I was following the instructions on the wiki:
http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Developme
nt
>>>> I got to the section for testing the i386/pc386 without any
problems,
>>>> but then I tried to do tho the following command:
>>>> pc386 -i
./rtems-4.11-work/b-pc386/i386-rtems4.11/c/pc386/testsuites/samples/hell
o/hello.exe
>>>> and got this error:
/home/rtems/rtems-4.11-work/rtems-testing/bin/pc386: line 298:
>>>> type: qemu: not found
>>>> FAILED: Path appears to be broken (cannot find
qemu)
>>>> Any ideas as to what I am missing/doing incorrectly?
>>>> My ultimate goal is to run lm3s6965 instead of pc386, but I
get the same
>>>> error with either.
>>>> Thanks,
>>>> Aric Hunter
>>> Joel Sherrill, Ph.D. Director of Research&
Development
>>> joel.sherrill at OARcorp.com On-Line Applications
Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
<tel:%28256%29%20722-9985>
Development
Research
Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20120719/d320fd00/attachment-0001.html>
