Fw: Scheduling
z f zahra.faaaa at ymail.com
Sun Jul 22 05:59:11 UTC 2012
in RTEMS POSIX API User’s Guide says rtems support 4 policy .my question is: assume I want to use FIFO for thread scheduling in rtems .when and how I should make change during config.
rtems supports multithread and should have a policy to scheduling.is it right?
________________________________
To: z f <zahra.faaaa at ymail.com>
Cc: "rtems-users at rtems.org" <rtems-users at rtems.org>
Sent: Saturday, 21 July 2012, 22:05
Subject: Re: Scheduling
On 07/21/2012 12:27 PM, z f wrote:
> hi
> as I  know rtems has 4 scheduling policies.how can we select one of them during configuration?
> thanks
In 4.10 and older, there is one scheduling algorithm which
can be impacted by use of task/thread priority, preemption settings
and timeslice settings.
In the git head, you can select alternative scheduling algorithms
as documented here:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/c_user_423.html#Configuring-a-System-Scheduler-Algorithm-Configuration
--joel
URL: <http://lists.rtems.org/pipermail/users/attachments/20120721/026d04e0/attachment-0001.html>
