sparc-rtems4.11-gcc error
Jiri Freyvald
jiri.freyvald at gmail.com
Mon Jul 30 14:24:18 UTC 2012
Luca,
you don't need to compile hello.c from command line, using makefile is
much easier.
But if you still need it, build some example using makefile,as we all
suggested, and redirect output to file and you'll probably see all
parameters for gcc
(for compilation and for linking)
or you can look into $(RTEMS_MAKEFILE_PATH)/Makefile.inc - you'll find
all parameters there too
Jiri
On 07/30/12 14:23, Luca Cinquepalmi wrote:
> Jiri, I exactly did what you have just suggested me. My target is
> leon2 so I did
> cd rtems
> export PATH=/opt/rtems-4.11/bin:$PATH
> ./bootstrap
> cd ..
> mkdir b-sis
> cd b-sis
> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=leon2 \
> --enable-tests=samples --disable-posix --prefix=/opt/rtems-4.11
> make
> and everything went ok
> Supposing that I have a simple hello.c rtems file, could you please
> indicate me the complete command line to compile it?
> *sparc-rtems4.11-gcc ...........*
> Maybe i miss some options... Thank you again.
> Luca
> Il 30/07/2012 13.24, Jiri Freyvald ha scritto:
>> Luca,
>> I installed RTEMS for sparc and arm targets and both worked out of
>> the box (the same version as you have).
>> I would recomend you to leave Eclipse for that moment and build from
>> command line only.
>> The easiest way to make your application working is to follow those
>> tutorials:
>> http://wiki.rtems.org/wiki/index.php/Quick_Start
>> Have you built this: ?
>> cd rtems
>> ./bootstrap
>> cd ..
>> mkdir b-sis
>> cd b-sis
>> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis \
>> make
>> Everything went ok?
>> If yes, you will have a few examples in the build tree, you can run them.
>> Next step which I did and I recomend you too is:
>> http://www.rtems.org/wiki/index.php/Example_Application_Compiling
>> which will completely build a lot of examples and you can then use
>> some of them as a framework for your application.
>> The key thing you have to do is to properly set environment *PATH*
>> for your toolchain and *RTEMS_MAKEFILE_PATH*,
>> then you can run your application located out of the build tree.
>> You can very easily use its makefile, modify it and it will work for
>> you (even from Eclipse if you use a Makefile project)
>> I hope it will help
>> Jiri
>> On 07/30/12 11:49, Luca Cinquepalmi wrote:
>>> Hi Jiri, thank you for your suggestion.
>>> I've tryed it, but nothing happened. I tell you my source version:
>>> - rtems 4.11
>>> - binutils 2.22
>>> - gcc 4.7.1
>>> - newlib 1.20.0
>>> I really don't understand what kind of error I generate. RTEMS
>>> compilation and installation
>>> (as indicated in RTEMS Quick Start) has been performed withou any
>>> kind of errors.
>>> Do you have any other suggestion form me?
>>> Thanks a lot
>>> Luca
>>> Il 27/07/2012 16.37, Jiri Freyvald ha scritto:
>>>> Have you added -c option to sparc-rtems4.11-gcc command line
>>>> parameters?
>>>> (to ONLY compile and assemble single C file, but do not link)
>>>> because that error message seems to me as result of linking process
>>>> Jiri
>>>> On 07/27/12 10:38, Luca Cinquepalmi wrote:
>>>>> I'm using sparc-rtems4.11-gcc to compyle a rtems C source file.
>>>>> I compiled allthing as indicatedin web Quick start without any
>>>>> problems.
>>>>> When I try to compile a simplke rtems C source code the following
>>>>> errors appears:
>>>>> *- In function `bsp_get_work_area':/../../...../ undefined
>>>>> reference to `rdb_start'
>>>>> - In function `_Thread_Handler':/../../......./ undefined
>>>>> reference to `_init'*
>>>>> Has anybody seen these kind of errors before? I'm not able to
>>>>> solve them?
>>>>> Here my compilation options:
>>>>> *sparc-rtems4.11-gcc -B/opt/rtems-4.11/sparc-rtems4.11/leon2/lib \
>>>>> -specs
>>>>> /opt/rtems-4.11/sparc-rtems4.11/leon2/lib/bsp_specs \
>>>>> -mcpu=v8 -qrtems
>>>>> -L/opt/rtems-4.11/sparc-rtems4.11/leon2/lib*
>>>>> PS: I'm using Eclipse as IDE.
>>>>> Thanks a lot!
>>>>> Luca
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120730/17e808e5/attachment-0001.html>
