Clarification on Rate montonic
domenico.dileo at unina.it domenico.dileo at unina.it
Wed Jun 6 09:05:48 UTC 2012
Dear Sebastian and Gedare,
thank you for your comments.
I updated the code according to your suggestions
(at least I hope so). The cods is at the end of this message (with an
execution log as well).
In the init function 2 tasks, TA0 and TA1 are crated.
TA0 starts a periodic task,PER0, similarly TA1.
PER0 has period 6000 ticks and sleeps for 4000 ticks
PER1 has period 4000 ticks and sleeps for 2000 ticks
  I observer the following behavior:
TA0 and TA1 both created.
TA0 starts PER0.
PER0 executes (I choose to execute the task for 10 times)
Then everything stops.
Conversely, what I would like to see that
PR0 and PR1 are alternatively scheduled.
Can you help me out to understand where I'm mistaken?
Thank you in advance
init.c
int index = 0;
  for ( index; index < 2 ; index++ ) {
       task_names[ index ] =  rtems_build_name( 'T', 'A', '0'+index, ' ' );
       status = rtems_task_create(
       task_names[ index ],
       Priorities[ index ],
       RTEMS_MINIMUM_STACK_SIZE,
       RTEMS_DEFAULT_MODES,
       RTEMS_DEFAULT_ATTRIBUTES,
       &task_id[ index ]
     if(status == RTEMS_SUCCESSFUL){
	printf(" Task %s created with id %d \n",
rtems_object_get_name(task_id[index],NAME_LENGTH, task_name),
task_id[index]);
		}else{
		printf("Failed to create task %s  with status %i \n",
task_name[index], status);
   rtems_rate_monotonic_reset_all_statistics();
   for ( index = 0 ; index < 2 ; index++ ) {
     status = rtems_task_start( task_id[ index ], periodic_task, index );
	printf(" Task %s started \n",
rtems_object_get_name(task_id[index],NAME_LENGTH, task_name));
		}else{
		printf("Failed to start task %s  with status %d \n",
//wake up init after 20 seconds
  status = rtems_task_wake_after(ticks_per_second*60);
   // delete init task after starting the three working tasks
   rtems_rate_monotonic_report_statistics();
  status = rtems_task_delete( RTEMS_SELF );
   rtems_shutdown_executive(result);
tasks.c
rtems_task periodic_task(
   rtems_task_argument argument
   rtems_name rm_name;
   rtems_id rm_id;
   rtems_time_of_day time;
   rtems_status_code status;
   rtems_interval interval;
   uint32_t          ticks_since_boot;
   uint32_t          count;
   char rm_name_buffer[NAME_LENGTH];
   count = 0;
         rm_name = rtems_build_name( 'P', 'R', '0'+argument, ' ' );
	status = rtems_rate_monotonic_create(rm_name, &rm_id);
	printf("Periodic Task %s created with id %d \n",
rtems_object_get_name(rm_id,NAME_LENGTH, rm_name_buffer), rm_id);
		}else{
		printf("Failed to create task %s  with status %i \n", rm_name, status);
while( count < 10 ) {
     count++;
     status = rtems_clock_get_tod( &time );
     if(status != RTEMS_SUCCESSFUL){
	printf("\n FAILED TO GET TIME OF THE DAY \n");
   printf("\n\n %s - is running \n",
rtems_object_get_name(rm_id,NAME_LENGTH,rm_name_buffer));
   print_time( " - current time - ", &time, "\n" );
   ticks_since_boot = rtems_clock_get_ticks_since_boot();
   printf(" - Ticks since boot: %" PRIu32 "\n", ticks_since_boot);
   status = rtems_rate_monotonic_period(rm_id,Periods[argument]);
  	if(status == RTEMS_TIMEOUT){
		rtems_rate_monotonic_delete(rm_id);
   printf("\n Iteraction %d \n", count);
status = rtems_task_wake_after(wake[argument]);
Execution
Ticks per second in your system: 2000
Ticks since boot: 306
  Task TA0  created with id 167837698
  Task TA1  created with id 167837699
  Task TA0  started
Periodic Task PR0  created with id 1107361793
  PR0  - is running
  - current time - 00:00:00   05/05/2012
  - Ticks since boot: 306
  Iteraction 1
  PR0  - is running
  - current time - 00:00:02   05/05/2012
  - Ticks since boot: 4393
  Iteraction 2
  PR0  - is running
  - current time - 00:00:05   05/05/2012
  - Ticks since boot: 10395
  Iteraction 3
  PR0  - is running
  - current time - 00:00:08   05/05/2012
  - Ticks since boot: 16420
  Iteraction 4
  PR0  - is running
  - current time - 00:00:11   05/05/2012
  - Ticks since boot: 22411
  Iteraction 5
  PR0  - is running
  - current time - 00:00:14   05/05/2012
  - Ticks since boot: 28421
  Iteraction 6
  PR0  - is running
  - current time - 00:00:17   05/05/2012
  - Ticks since boot: 34419
  Iteraction 7
  PR0  - is running
  - current time - 00:00:20   05/05/2012
  - Ticks since boot: 40411
  Iteraction 8
  PR0  - is running
  - current time - 00:00:23   05/05/2012
  - Ticks since boot: 46421
  Iteraction 9
  PR0  - is running
  - current time - 00:00:26   05/05/2012
  - Ticks since boot: 52414
  Iteraction 10
Period information by period
--- CPU times are in seconds ---
--- Wall times are in seconds ---
    ID     OWNER COUNT MISSED          CPU TIME                  WALL TIME
                                     MIN/MAX/AVG                MIN/MAX/AVG
0x42010001          9      0 0.053411/0.079910/0.069353
2.053487/2.080012/2.069391
Quoting Gedare Bloom <gedare at rtems.org>:
> Hi,
> Your code has a couple of bugs. See for example sp20 for how to
> structure a typical RM application. One problem I see is that your
> init task calls the periodic_task() function directly. Instead you
> should be setting up a normal rtems_task_create/rtems_task_start with
> periodic_task as the entry point, and periodic_task would: create an
> rm timer, self-suspend so that all periodic tasks release
> simultaneously (critical instant), and execute the periodic loops.
> Init should either suspend indefinitely/delete itself or can be used
> to stop the application similarly to how you have set it up with
> wake_after.
> -Gedare
> On Mon, Jun 4, 2012 at 5:29 PM,  <domenico.dileo at unina.it> wrote:
>> Hello,
>> With the code hereafter, I run two periodic tasks (PER0 and PER1)
>> and scheduled them with the rate monotonic.
>> Also, a log of the excution follows the code.
>> PER0 has period 6000 ticks, while PER1 215.
>> Questions:
>> a) Since PER0 's pariod >> PER1's period should be PER1
>> the first to be scheduled?
>> According to the log, PER0 is the first one
>> b) how should I modify the code in order to have
>> PER1 scheduled before PER0?
>> Of course if I swap periodic_task(task_id[0], 6000);
>> with periodic_task(task_id[0], 215) I can observer
>> PER1 scheuled before PER0.
>> It seems that the first task to be scheduled
>> is the first to execute (with the call to the function
>> rtems_rata_monotonic_period).
>> Thank you in advance,
>> init.c code
>>  int i = 0;
>>  int l = 1;
>>  for(i; i< 3; i++){
>>        task_names[ i ] = rtems_build_name( 'P', 'R', '0'+i , ' ' );
>>        status = rtems_rate_monotonic_create(task_names[i], &task_id[i]);
>>        printf("Task %s created with id %d \n",
>> rtems_object_get_name(task_id[i],sizeof(task_names[i]),task_name),
>> task_id[i]);
>>                }else{
>> rtems_object_get_name(task_id[i],NAME_LENGTH,task_name), status);
>> //rtems_rate_monotonic_reset_all_statistics();
>> //for(i = 0; i < 3; i++)
>> periodic_task(task_id[1], 215);
>> //wake up init after 5 seconds
>>  status = rtems_task_wake_after(ticks_per_second*10);
>> int j = 0;
>> for(j; j<=3;j++){
>>        rtems_rate_monotonic_delete(task_id[j]);
>> tasks.c
>>  rtems_id task_id,
>>  rtems_interval period
>>  uint32_t          count;
>>  char task_name[NAME_LENGTH];
>>  count = 0;
>>  //task_id = rtems_task_self();
>>    count++;
>> rtems_object_get_name(task_id,NAME_LENGTH,task_name));
>>  status = rtems_rate_monotonic_period(task_id,period);
>>                rtems_rate_monotonic_delete(task_id);
>> LOG
>> Task PR1 created with id 1107361794
>> Task PR2 created with id 1107361795
>>  PR0  - is running
>>  - Ticks since boot: 0
>>  PR0  - is running
>>  PR0  - is running
>>  - current time - 00:00:03   05/05/2012
>>  - Ticks since boot: 6076
>>  PR0  - is running
>>  - current time - 00:00:06   05/05/2012
>>  - Ticks since boot: 12055
>>  PR0  - is running
>>  - current time - 00:00:09   05/05/2012
>>  - Ticks since boot: 18087
>>  PR0  - is running
>>  - current time - 00:00:12   05/05/2012
>>  - Ticks since boot: 24068
>>  PR0  - is running
>>  - current time - 00:00:15   05/05/2012
>>  - Ticks since boot: 30099
>>  PR0  - is running
>>  - current time - 00:00:18   05/05/2012
>>  - Ticks since boot: 36098
>>  PR0  - is running
>>  - current time - 00:00:21   05/05/2012
>>  - Ticks since boot: 42071
>>  PR0  - is running
>>  - current time - 00:00:24   05/05/2012
>>  - Ticks since boot: 48072
>>  PR1  - is running
>>  - current time - 00:00:27   05/05/2012
>>  - Ticks since boot: 54096
>>  PR1  - is running
>>  - Ticks since boot: 54200
>>  PR1  - is running
>>  - Ticks since boot: 54423
>>  PR1  - is running
>>  - Ticks since boot: 54655
>>  PR1  - is running
>>  - Ticks since boot: 54840
>>  PR1  - is running
>>  - Ticks since boot: 55104
>>  PR1  - is running
>>  - Ticks since boot: 55271
>>  PR1  - is running
>>  - Ticks since boot: 55526
>>  PR1  - is running
>>  - Ticks since boot: 55712
>>  PR1  - is running
>>  - Ticks since boot: 55937
>> 0x42010001 UI1      9      0 0.000000/0.065991/0.047860
>> 0.000000/0.066002/0.047885
>> 0x42010002 UI1      9      0 0.044008/0.078422/0.058316
>> 0.044010/0.078501/0.058371
>> 0x42010003 UI1      0      0
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Domenico Di Leo, PhD student, Universit? degli Studi di Napoli Federico II
Ph:     +39 081 676770
Fax:    +39 081 676574
Web: http://wpage.unina.it/domenico.dileo
