File systems on SD memory devices
ali nasir
supremenasir at yahoo.com
Sat Jun 9 06:35:34 UTC 2012
Hello,
What file systems are appropriate to these devices?
---If you want these cards to be written or read from a standard desktop PC also, then any of the FAT will be the most appropriate for the card.
What are the pros and cons?
--Pros and cons for using the card??I did not underatand this concern of yours.
We don't want to infringe on anyone's patents, so probably FAT is out, right?
--I have no idea of any licensing issues. But the SD cards from the market already come formatted with the FAT. Hence i guess the licensing issues might already have been sorted out. But i am not sure
Does RTEMS already support something appropriate?
- Yes. RTEMS support MSFAT32, MSFAT16, Rtems File System (RFS). The RFS is mainly recommended to have a Filesystem within the embedded target itself like a filesystem on RAM or Flash device.
If not, is it something we should work toward contributing?
It would be nice if the format is supported by Linux, MacOS and/or Windows, but not strictly required.
--FAT is already supportd i guess by Linux, MAC OS and windows.
Regards,
Ali
________________________________
To: "rtems-users at rtems.org List" <rtems-users at rtems.org>
Sent: Friday, June 8, 2012 10:49 AM
Subject: File systems on SD memory devices
Our RTEMS-based project will use micro-SD memory devices to store boot and application images, as well as configuration information files. I am charged with interfacing the hardware to our software, possibly via RTEMS. This is new territory for me, so I am wondering whether people in the community would share their wisdom with me.
Thanks for any advice you can give me.
Cheers,
Ric
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120608/176cb0ef/attachment.html>
