managers
Tue Jun 19 13:08:17 UTC 2012
On 06/19/2012 02:38 PM, Pierre Ficheux wrote:
> My question was actually about .exe size reduction (a kind of FAQ...). I've
> read some discussion (http://comments.gmane.org/gmane.os.rtems.user/10658)
> about removing some libs:
> "You need disable MINIIMFS, libio and libc, and exclude the console from your
> Makefile. This will make your minium.exe less than 20K"
> Actually how is it possible? modifying source tree?
No, you can do this at link time.  You have to know the right configuration
parameters.  This should give the absolute minimum:
static void *idle_body(uintptr_t ignored)
   while (true) {
     /* Do nothing */
   return NULL;
#define CONFIGURE_INIT
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
#define CONFIGURE_UNIFIED_WORK_AREAS
#define CONFIGURE_MAXIMUM_PRIORITY 3
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY idle_body
#include <rtems/confdefs.h>
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
