RTEMS and libc
Fri Mar 2 22:51:07 UTC 2012
On Fri, Mar 2, 2012 at 5:54 AM, Juan Pablo Rumie Vittar
<jvittar at faa.mil.ar> wrote:
> Hello,
> One question: how I can compile an example (RTEMS), using the functions
> dlopen, dlclose, etc?
> If the sentence: "# include <dlfcn.h>"
> no works already (apparently) with the gcc compiler RTEMS?
> I guess (the gcc compiler RTEMS) instead of using "libc" used "newlib"
> I can do to solve the problem?
> thanks in advance
There is experimental work in progress to support dynamic linking that
IIRC uses dlopen/dlclose; the main author is Chris Johns. I suspect it
will be in the release of 4.11.
-Gedare
> Generado por el Webmail de la Fuerza Aerea Argentina
> Este mensaje ha sido analizado por MailScanner
> en busca de virus y otros contenidos peligrosos,
> y se considera que está limpio.
> rtems-users mailing list
> rtems-users at rtems.org
