Starting with RTEMS
Binkowski, Cassio
cassioiks at gmail.com
Sat Mar 3 22:26:28 UTC 2012
On Thu, Mar 1, 2012 at 8:59 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 2/03/12 9:55 AM, Binkowski, Cassio wrote:
>> Have you cut off some of the output ?
>> Nope. This is it. I know in the wiki it shows a lot more.
> Interesting. I wonder if gcc has changed what it does between the versions
> in 4.10 and 4.11 so -v is passed to the various parts it uses. I like the
> 4.11 behaviour.
>> But so far you can't tell if anything is wrong, right?
> From what I can see it would seem ok. The only way to tell is to build
> RTEMS but I am sure you know this. :)
I have done the process all over again but still accusing that there is no
g++ and c++.
Would it be better if I download an image and run it with virtual box?
Also, if I were to compile the hello_world_c sample app. Where should I put
this hello_world_c folder?
Cassio
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20120303/854e243a/attachment.html>
