Starting with RTEMS
Ralf Corsepius ralf.corsepius at rtems.org
Sun Mar 4 15:38:24 UTC 2012
On 03/04/2012 04:30 PM, Gedare Bloom wrote:
> On Sun, Mar 4, 2012 at 10:14 AM, Binkowski, Cassio<cassioiks at gmail.com>  wrote:
>> On Sun, Mar 4, 2012 at 3:44 AM, Chris Johns<chrisj at rtems.org>  wrote:
>>> On 4/03/12 9:26 AM, Binkowski, Cassio wrote:
>>>> I have done the process all over again but still accusing that there is
>>>> no g++ and c++.
>>> What is reporting it cannot find g++ and c++ ?
>> Ok, the exact lines are the following:
>> checking for avr-rtems4.10-g++... no
>> configure: error: no acceptable c++ found in $PATH
>> configure: error:
>> ../../../../../../rtems-4.10.2/c/src/../../testsuites/samples/
>> configure failed for samples
>> configure: error: /bin/sh
>> '../../../../../rtems-4.10.2/c/src/../../testsuites/co
>> nfigure' failed for ../../testsuites
>> make[2]: *** [avrtest] Error 1
>> make[2]: Leaving directory
>> `/c/opt/rtems-4.10/rtems4.10-build/avr-rtems4.10/c'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> make: *** [all-recursive] Error 1
>> These the last lines of a large dump generated by the command "make all".
> What is:
>    $ which avr-rtems4.10-g++
The avr-gcc does not support C++.
=> There is no  avr-rtems4.10-g++
Ralf
