Starting with RTEMS
Ralf Corsepius
ralf.corsepius at rtems.org
Sun Mar 4 16:56:50 UTC 2012
On 03/04/2012 05:38 PM, Binkowski, Cassio wrote:
> On Sun, Mar 4, 2012 at 12:36 PM, Ralf Corsepius
> <ralf.corsepius at rtems.org <mailto:ralf.corsepius at rtems.org>> wrote:
> On 03/04/2012 04:14 PM, Binkowski, Cassio wrote:
> On Sun, Mar 4, 2012 at 3:44 AM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>
> <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> On 4/03/12 9:26 AM, Binkowski, Cassio wrote:
> I have done the process all over again but still
> accusing that
> there is
> no g++ and c++.
> What is reporting it cannot find g++ and c++ ?
> Ok, the exact lines are the following:
> checking for avr-rtems4.10-g++... no
> configure: error: no acceptable c++ found in $PATH
> configure: error:
> ../../../../../../rtems-4.10. 2/c/src/../../testsuites/ samples/
> configure failed for samples
> configure: error: /bin/sh
> '../../../../../rtems-4.10.2/ c/src/../../testsuites/co
> nfigure' failed for ../../testsuites
> make[2]: *** [avrtest] Error 1
> make[2]: Leaving directory
> `/c/opt/rtems-4.10/rtems4.10- build/avr-rtems4.10/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [all-recursive] Error 1
> These the last lines of a large dump generated by the command
> "make all".
> How does your call to configure look like?
> Just like this:
> ../rtems-4.10.2/configure --target=avr-rtems4.10
> --enable-rtemsbsp=avrtest --enable-cxx --enable-tests=samples
--enable-cxx is the culprit of the abort above.
You are explicitly demanding the configure script to use C++, which
fails for the avr, because the avr does not support C++.
Omit this option from the configure-call and your configuration should
finish without problems.
> How can I download a pre-built development environment?
Which OS rsp. distro?
> The only virtual machine I could find was a CentOS machine. Which was
> discontinued by the way.
This is a misunderstanding. The RTEMS toolchains for CentOS 4 were
discontinued, because this distribution's vendor has discontinued it.
CentOS 5 and CentOS 6 are well alive and so are the corresponding RTEMS
toolchain packages.
c.f.
ftp://ftp.rtems.org/pub/rtems/linux/<rtems-version>/centos/<centos-version>
e.g. ftp://ftp.rtems.org/pub/rtems/linux/4.10/centos/6
Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20120304/990ab6c6/attachment.html>
