RTEMS on x86 PC
Fered
a_Fered at yahoo.com
Mon Mar 5 06:31:17 UTC 2012
Hi;
Can I boot RTESM from hard disk using GRUB instead of floppy?
Thanks
> Hi,
> Yes you can test RTEMS in your PC. You just have to build RTEMS for
> the i386 architecture and pc386 (or later) board support package. Once
> you have a RTEMS application built you can use GRUB to boot it. (if
> you have grub already installed on your PC you just have to change the
> "kernel=" parameter to point to an RTEMS application)
> For more information on how to build RTEMS and a sample application:
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> http://wiki.rtems.org/wiki/index.php/Quick_Start
> http://wiki.rtems.org/wiki/index.php/Example_Application_Compiling
> For more information about the boot:
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/i386/pc386/HOWTO
> http://wiki.rtems.org/wiki/index.php/Pc386
> http://wiki.rtems.org/wiki/index.php/QEMU
> Cláudio
> On Wed, Feb 22, 2012 at 11:03 AM, harryxiyou <harryxiyou at gmail.com> wrote:
> > On Wed, Feb 22, 2012 at 3:58 PM, Fered <a_fered at yahoo.com> wrote:
> >> Hi,
> > Hi there,
> >> I'm newbie and want to test RTEMS on my PC.(on real hardware)
> >> Is it possible?
> > I think it is ok for us to test on our PC. I am now searching the way,
> > too. I recommend some useful links for you. If you find the way tell me
> > please.
> > [0] http://wiki.rtems.org
> > [1] http://www.rtems.org/
> > [2] http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> > [3] http://git.rtems.org/
> > Thanks
> > Harry Wei
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
