Any arm-rtems users?
Kirspel, Kevin kevin.kirspel at optimedical.com
Tue Mar 6 18:23:28 UTC 2012
I am an arm-rtems user (NXP LPC3250 BSP).  Our makefiles are structured so that changing the GCC compiler is simple.  I assume changes are needed for linkcmds since they are currently elf based.  I don't see why I couldn't easily switch.  But I may not know all the issues.  I am currently using an ARM Cortex-M3 (arm-none-eabi) on a non-rtems platform and have had no issues.
Just my two cents.
Message: 3
Date: Tue, 06 Mar 2012 10:24:42 +0100
To: RTEMS Users <rtems-users at rtems.org>
Subject: Any arm-rtems users?
Message-ID: <4F55D7DA.6020904 at rtems.org>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi,
Does anybody use arm-rtems?
I am asking, because with gcc-4.7.x, the FSF's GCC has abandoned
arm-rtems (== arm-*elf*) and is furtheron only supporting arm-rtemseabi
(== arm-*eabi*).
Please speak up now, if your works or BSP rely upon arm-rtems and if you
can't switch to arm-rtemseabi.
We need to find a way to handle this situation and it's currently
unclear how to proceed.
Ralf
