Not building Sample app in CentOS
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 8 19:24:46 UTC 2012
On 03/08/2012 12:51 PM, Binkowski, Cassio wrote:
> Hi everyone. I'm not being able to make the Hello application in the
> CentOS Virtual Machine.
> Please see below the steps I took to build RTEMS and then try building
> the Hello World app.
> 1) Created the folder TEST in /home/rtems.
> 2) In the terminal, inside the folder TEST:
> 2.1) export PATH=/opt/rtems-4.11/bin:${PATH}
> 2.2) ~/rtems-4.11-work/rtems/configure --target=sparc-rtems4.11
> --disable-posix --disable-networking --disable-cxx
> --enable-rtemsbsp=sis --enable-tests=samples
There is no --prefix option on this to specify an install point.
If you used --prefix=/home/rtems/rtems-4.11-work/bsp-install,
then RTEMS_MAKEFILE_PATH would be set to
/home/rtems/rtems-4.11-work/bsp-install/sparc-rtems4.11/sis
> 2.3) gmake all
No install step
> 3) Copied the folder Samples from
> ~/rtems-4.11-work/rtems/testsuites/samples. Pasted it inside the TEST
> folder.
> -- The HELLO folder, inside Samples, has the following contents:
> hello.doc
> hello.scn
> init.c
> Makefile.am
> Makefile.in
The Makefile.* indicates it is an autoconf build system
and (for RTEMS) only works inside the source tree.
3.1) still inside the Terminal: export
RTEMS_MAKEFILE_PATH=/home/rtems/test/sparc-rtems4.11/sis
There is a set of example programs .. examples-v2 which use a simple
build system and use RTEMS_MAKEFILE_PATH to find the BSP installation.
Grr... violated my own rule of rushing something to get out the door
before a
weekend, trip, or holiday. You always end up in a hurry and missing stuff.
The VM is missing the checkout of examples-v2. :(
cd ~/rtems-4.11-work
git clone git://git.rtems.org/examples-v2.git
Then there are various programs which can be built using the
RTEMS_MAKEFILE_PATH build system and an installed RTEMS.
Look in the subdirectory hello and you will see 3 hello world variants
that can be built against an install RTEMS.
> 3.2) I have tried 2 commands to try in making it, unsuccessfully
> though. See below:
> [rtems at localhost hello]$ make
> make: *** No targets specified and no makefile found. Stop.
> [rtems at localhost hello]$ make -f Makefile.am
> Makefile.am:12: /make/custom/@RTEMS_BSP at .cfg: No such file or directory
> Makefile.am:13: /../automake/compile.am <http://compile.am>: No such
> file or directory
> Makefile.am:14: /../automake/leaf.am <http://leaf.am>: No such file or
> directory
> Makefile.am:24: /../automake/local.am <http://local.am>: No such file
> or directory
> make: *** No rule to make target `/../automake/local.am
> <http://local.am>'. Stop.
> [rtems at localhost hello]$ make -f Makefile.in
> Makefile.in:16: *** missing separator. Stop.
The Makefile.am is a very stylized file which is processed by two
tools to get the real Makefile.
> I guess I'm missing something or just trying to build Hello World in
> the wrong folder.
> Can you guys help me out?
You ran into another of my mistakes.
On a positive note, you are making a good impression. The reports and
catching the mistakes are awesome. I will update the VM when you
succeed and we go through the issues you had to make sure I fixed them.
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120308/11f9ab30/attachment.html>
