Building project - Eclipse
Binkowski, Cassio cassioiks at gmail.com
Mon Mar 12 14:04:11 UTC 2012
I have been trying to build a test project in eclipse but have neen unable
to do so.
The configuration I've been using are the following:
Base path: /opt/rtems-4.11
BSP pah: /home/rtems/test/sparc-rtems4.11
It is giving me this:
make invokation `make PROJECT_RELEASE=/home/rtems/test/sparc-rtems4.11'
returned with error status 2
And Eclipse is returning the following, when trying to build:
**** Build of configuration RTEMS Executable Configuration for project test
make all
Building file: ../init.c
Invoking: RTEMS C Compiler
/opt/rtems-4.11/bin/gcc -Os -g -Wall -c -fmessage-length=0 -pipe -MMD -MP
-MF"init.d" -MT"init.d" -o "init.o" "../init.c"
/bin/sh: /opt/rtems-4.11/bin/gcc: No such file or directory
make: *** [init.o] Error 127
**** Build Finished ****
Can I have your advice? I have tried a few combinations on the Base and BSP
path.
Regards
Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20120312/1959b035/attachment.html>
