Building project - Eclipse
Binkowski, Cassio
cassioiks at gmail.com
Mon Mar 12 15:57:57 UTC 2012
On Mon, Mar 12, 2012 at 12:55 PM, Sebastian Huber <
> On 03/12/2012 04:23 PM, Binkowski, Cassio wrote:
>> On Mon, Mar 12, 2012 at 11:14 AM, Sebastian Huber
>> <sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>
>> wrote:
>> On 03/12/2012 03:04 PM, Binkowski, Cassio wrote:
>> I have been trying to build a test project in eclipse but have neen
>> unable to
>> do so.
>> The configuration I've been using are the following:
>> Base path: /opt/rtems-4.11
>> BSP pah: /home/rtems/test/sparc-rtems4.**__11
>> This is not a BSP path, try /home/rtems/test/sparc-rtems4.**__11/sis
>> or
>> whatever BSP you want.
>> Well, it is still returning that "make invokation, error status 2".
>> Is there anything else I can do?
> Did you build an install a BSP? Which name has it?
Yes. I believe I did. I have built the SIS BSP for Sparc.
However, I'm not sure how the installation process works.
Can you help me out?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120312/22756da2/attachment.html>
