Building project - Eclipse
Binkowski, Cassio
cassioiks at gmail.com
Mon Mar 12 17:12:07 UTC 2012
On Mon, Mar 12, 2012 at 12:26 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
> On Mon, Mar 12, 2012 at 11:18 AM, 阿四 <ashi08104 at gmail.com> wrote:
>> hi, since you are do cross-compiling, I think the call to gcc is not
>> right.
>> > Building file: ../init.c
>> > Invoking: RTEMS C Compiler
>> > /opt/rtems-4.11/bin/gcc -Os -g -Wall -c -fmessage-length=0 -pipe -MMD
>> -MP
>> accordding to your target, sparc-rtems4.11-gcc should be called.
I tried to replace the path in C/C++ build > Settings
> for sparc-rtems4.11-gcc, instead of just gcc.
> It just changes back to the original thing.
> I don't know how to make it call sparc-rtems4.11-gcc. Can you help?
It keeps calling only GCC, instead of sparc-rtems4.11-gcc.
>> best regards!
>> zw_yao
URL: <http://lists.rtems.org/pipermail/users/attachments/20120312/7df13f72/attachment.html>
