Building project - Eclipse
Binkowski, Cassio
cassioiks at gmail.com
Wed Mar 14 12:35:09 UTC 2012
On Wed, Mar 14, 2012 at 4:36 AM, Sebastian Huber <
> On 03/13/2012 11:11 PM, Binkowski, Cassio wrote:
>> On Tue, Mar 13, 2012 at 5:53 PM, Binkowski, Cassio <cassioiks at gmail.com
>> <mailto:cassioiks at gmail.com>> wrote:
>> On Tue, Mar 13, 2012 at 5:28 PM, Sebastian Huber
>> <sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>
>> wrote:
>> On 13/03/12 19:00, Binkowski, Cassio wrote:
>> On Tue, Mar 13, 2012 at 11:10 AM, Sebastian Huber<
>> sebastian.huber at embedded-__**brains.de<sebastian.huber at embedded-__brains.de>
>> wrote:
>> On 03/13/2012 05:07 PM, Binkowski, Cassio wrote:
>> What is the build directory name?
>> It is actually build.
>> /home/rtems/build
>> The prefix must not be a subdirectory of the build
>> directory.
>> I don't understand. Can you then point me the direction?
>> Thanks
>> In another mail you write this:
>> ~/rtems-4.11-work/rtems/__**configure --target=sparc-rtems4.11
>> --disable-posix
>> --disable-networking --disable-cxx --enable-rtemsbsp=sis
>> --enable-tests=samples --prefix=/home/rtems/build/__**
>> sparc-rtems4.11/sis
>> /home/rtems/build
>> Ok. It is correct.
>> => your prefix is a subdirectory of the build tree
>> This makes no sense and is wrong. Why not simply use the default
>> prefix?
>> But the default prefix Joel Sherril provided is the one that is
>> pointing
>> the the /sparc-rtems4.11/sis
>> What do you have for default?
>> /home/rtems/bild is where I have all things buit on.
>> I have configured it with prefix=/opt/rtems-4.11, still getting errors in
>> Eclipse.
> Quite frankly, you are so sparse with information, who should I know what
> "I have configured" is in your case?
>> Just for clarification:
>> Tools path: /opt/rtems-4.11
>> Source path: /home/rtems/rtems-4.11-work/**rtems
>> Build path: /home/rtems/build
>> Can you please advise?
> cd
> rm -rf build
> mkdir build
> cd build
> /home/rtems/rtems-4.11-work/**rtems/configure --target=sparc-rtems4.11
> --prefix=/opt/rtems-4.11 --disable-posix --disable-cxx
> --enable-rtemsbsp=sis --enable-tests=samples --disable-networking
> make
> make install
> If you get errors in this procedure fix them first. You need an installed
> BSP before you start with Eclipse!
When I "make install", in the last lines, I get that it entered a few
directories but there was nothing to do there.
Is this a bad sign?
The prefix for the configure command should then be located at the tools
path (/opt/rtems-4.11) ?
What's the correct location for Base path and BSP path in Eclipse?
Please tell me what do you do that made it work for you.
I am using the CentOS virtual machine, just in case.
Regards
URL: <http://lists.rtems.org/pipermail/users/attachments/20120314/25ef3062/attachment.html>
