Fwd: ./bootstrap problem!!
vai bas
vai.csse at gmail.com
Fri Mar 16 13:21:09 UTC 2012
I have cloned from the git clone git://git.rtems.org/rtems.git rtems and
found the bootstrap and got success. But again I have not found in top of
repository to do following steps:
Configure and build
$ cd ..
$ mkdir b-rtems-4.9-testing
$ cd b-rtems-4.9-testing/
$ ../rtems-cvs-20080911/configure --enable-rtems-debug \
--target=powerpc-rtems4.9 --enable-posix --prefix=/opt/rtems-4.9 \
--enable-networking --enable-cxx --enable-rtemsbsp="virtex"
--enable-maintainer-mode
$ make all
There is not any configure file inside of rtems cloned from given link
above. my process and error :
../rtems/configure --enable-rtems-debug \ --target=i386-rtems4.11
--enable-posix --prefix=/opt/rtems-4.11 \ --enable-networking --enable-cxx
-enable-rtemsbsp="virtex" --enable-maintainer-mode
bash: ../rtems/configure: No such file or directory
best regards
Suresh
On Fri, Mar 16, 2012 at 5:08 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> On 03/16/2012 07:32 AM, vai bas wrote:
>> Dear respected users,
>> Can someone told me about ./bootstrap error? Where can I
>> found this file? when I did ./bootstrap I found: No such file or directory?
>> Did someone get this type of error? Thank you as advance..
>> You are not in the top of the RTEMS source tree.
>> Best regards
>> Suresh
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120316/223600ca/attachment.html>
