./bootstrap problem!!
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 16 13:48:56 UTC 2012
Also notice versions in the example configure command. It says 4.9
and you have 4.11. Replace that.
On 3/16/2012 8:26 AM, Binkowski, Cassio wrote:
> On Fri, Mar 16, 2012 at 10:21 AM, vai bas <vai.csse at gmail.com
> <mailto:vai.csse at gmail.com>> wrote:
> I have cloned from the git clone git://git.rtems.org/rtems.git
> <http://git.rtems.org/rtems.git> rtems and found the bootstrap and
> got success. But again I have not found in top of repository to do
> following steps:
> Configure and build
> $ cd ..
> $ mkdir b-rtems-4.9-testing
> $ cd b-rtems-4.9-testing/
> $ ../rtems-cvs-20080911/configure --enable-rtems-debug \
> --target=powerpc-rtems4.9 --enable-posix --prefix=/opt/rtems-4.9 \
> --enable-networking --enable-cxx --enable-rtemsbsp="virtex" --enable-maintainer-mode
> $ make all
> There is not any configure file inside of rtems cloned from given
> link above. my process and error :
> ../rtems/configure --enable-rtems-debug \ --target=i386-rtems4.11
> --enable-posix --prefix=/opt/rtems-4.11 \ --enable-networking
> --enable-cxx -enable-rtemsbsp="virtex" --enable-maintainer-mode
> bash: ../rtems/configure: No such file or directory
> This is a reference path. It assumes you're inside the folder you want
> to build RTEMS and this folder is in the same level as the RTEMS
> source folder.
> Instead of using "../rtems/configure", try using the whole path. E.g:
> "/home/rtems/rtems-work/rtems/configure"
> best regards
> Suresh
> On Fri, Mar 16, 2012 at 5:08 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 03/16/2012 07:32 AM, vai bas wrote:
> Dear respected users,
> Can someone told me about ./bootstrap
> error? Where can I found this file? when I did ./bootstrap
> I found: No such file or directory? Did someone get this
> type of error? Thank you as advance..
> You are not in the top of the RTEMS source tree.
> Best regards
> Suresh
> Joel Sherrill, Ph.D. Director of Research&
> Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120316/776f8f59/attachment.html>
