Building error RTEMS 4.10.2
vai bas vai.csse at gmail.com
Thu Mar 22 12:32:36 UTC 2012
Dear respected RTEMS users,
              I am building RTEMS 4.10 in targeted system i386 intel.
Everything was going without error. But I found problem in the step of
Config and build binuitls-2.20.1. I am sorry for that post with error , But
I want to know about it. Can someone clear me about this matter?
Error as follows:
rtems/tools/b-binutils$ make info
make[1]: Entering directory `/home/vai/study/rtems/tools/b-binutils'
Doing info in bfd
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/bfd'
Making info in doc
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/bfd/doc'
make[3]: Nothing to be done for `info'.
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/bfd/doc'
Making info in po
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/bfd/po'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/bfd/po'
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/bfd'
make[3]: Nothing to be done for `info-am'.
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/bfd'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/bfd'
Doing info in opcodes
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/opcodes'
Making info in .
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/opcodes'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/opcodes'
Making info in po
`/home/vai/study/rtems/tools/b-binutils/opcodes/po'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/opcodes'
Doing info in binutils
`/home/vai/study/rtems/tools/b-binutils/binutils'
Making info in doc
`/home/vai/study/rtems/tools/b-binutils/binutils/doc'
Making info in po
`/home/vai/study/rtems/tools/b-binutils/binutils/po'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/binutils'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/binutils'
Doing info in etc
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/etc'
for f in standards.info configure.info; do \
  if test -f ../../binutils-2.20.1/etc/`echo $f | sed -e
's/.info$/.texi/'`; then \
    if make "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000"
$f; then \
      true; \
    else \
      exit 1; \
    fi; \
  fi; \
done
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/etc'
make[3]: `../../binutils-2.20.1/etc/standards.info' is up to date.
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/etc'
make[3]: `../../binutils-2.20.1/etc/configure.info' is up to date.
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/etc'
Doing info in gas
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gas'
Making info in doc
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gas/doc'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gas/doc'
Making info in po
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gas/po'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gas/po'
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gas'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gas'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gas'
Doing info in gprof
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gprof'
Making info in po
`/home/vai/study/rtems/tools/b-binutils/gprof/po'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gprof/po'
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/gprof'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gprof'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/gprof'
Doing info in intl
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/intl'
make[2]: Nothing to be done for `info'.
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/intl'
Doing info in ld
make[2]: Entering directory `/home/vai/study/rtems/tools/b-binutils/ld'
Making info in po
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/ld/po'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/ld/po'
make[3]: Entering directory `/home/vai/study/rtems/tools/b-binutils/ld'
make[3]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/ld'
make[2]: Leaving directory `/home/vai/study/rtems/tools/b-binutils/ld'
Doing info in libiberty
`/home/vai/study/rtems/tools/b-binutils/libiberty'
-I../../binutils-2.20.1/libiberty
../../binutils-2.20.1/libiberty/libiberty.texi
`/home/vai/study/rtems/tools/b-binutils/libiberty/testsuite'
make[1]: Nothing to be done for `info-target'.
make[1]: Leaving directory `/home/vai/study/rtems/tools/b-binutils'
vai at vai:~/study/rtems/tools/b-binutils$ make info
Doing info in bfd
Making info in doc
Making info in po
Making info in .
Making info in po
Making info in doc
Making info in po
Doing info in etc
$f; then \
      true; \
    else \
      exit 1; \
    fi; \
  fi; \
done
Doing info in gas
Making info in doc
Making info in po
Doing info in gprof
Making info in po
Doing info in intl
Doing info in ld
Making info in po
         Thanks as advance.
Best regards
URL: <http://lists.rtems.org/pipermail/users/attachments/20120322/6addbc11/attachment.html>
