Project about Atomic Operations
yangwei weiyang wei.a.yang at gmail.com
Mon Mar 26 13:45:35 UTC 2012
2012/3/26 yangwei weiyang <wei.a.yang at gmail.com>:
> Hi Huber:
>    The atomic operations supported by c and c++ standard is built in
> the compiler, like
> GCC has some build-in atomic operations functions. you can see
>    http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Atomic-Builtins.html.
>    But Not all operations are supported by all target processors and
> it is designed as a
> standard library not for a operation system. So in my opinion we can
> refer its implementation
> but can use them directly.
Correct but can not use them directly
> Wenjie
> Best Regards
> 2012/3/26 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>> Hi,
>> atomic operations are now supported by the recent C and C++ standard.  See
>> http://en.wikipedia.org/wiki/C11_%28C_standard_revision%29
>> http://www.hpl.hp.com/personal/Hans_Boehm/c++mm/
>> Why don't we simply use them?
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Wei Yang
> Best Regards
Wei Yang
Best Regards
