Problem in Integration of Analog / Digital Drivce driver with RTEMS for MVME162-522A
AJAI KUMAR MEDHAVI akmedhavi at rrcat.gov.in
Wed Mar 28 08:58:07 UTC 2012
Hi,
I have made Analog / Digital IO ( ADC, DAC, OPTO and Relay)  Device
drivers for MVME162-512 VME CPU Board using RTEMS 4.10.2 on Windows with
MinGW-get-inst-20110802 and RTEMS4.10 tools
Before integrating ADC / DAC Drivers, I have successfully configured,
build and run all sample and test applications on my CPU board.
Now I have added ADC/DAC Device Drivers for Four IO boards i.e ADC, DAC,
RELAY and OPTO. I have integrated Device Driver files in following steps :
1. First created a new folder ADCDAC in
               ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162
   And added following Files
	ADC.c
	DAC.c
	OPTO.c
	RELAY.c
   in ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162\ADCDAC directory.
2. Then modify makefile.am in   ..\rtems-4.10.2\c\src\lib\ libbsp\ m68k\
   mvme162
   With
# ADCDAC
libbsp_a_SOURCES += adcdac/adcdrv.c adcdac/dacdrv.c adcdac/optodrv.c \
		     adcdac/relaydrv.c
   to include ADC/DAC C files in makefile.
3. Then added Header files adc.h, dac.h, opto.h and realy.h
          In ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162\include
   And modify makefile.am in   ..\rtems-4.10.2\c\src\lib\ libbsp\ m68k\
                                mvme162
   With
	include_bspdir = $(includedir)/bsp
	dist_project_lib_DATA = bsp_specs
	include/adc.h include/dac.h include/opto.h include/relay.h
The modified makefile.am in ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162
is :
## $Id: Makefile.am,v 1.42 2008/09/30 10:32:49 ralf Exp $
ACLOCAL_AMFLAGS = -I ../../../../aclocal
include $(top_srcdir)/../../../../automake/compile.am
include_HEADERS = include/bsp.h include/adc.h include/dac.h include/opto.h
include/relay.h
include_HEADERS += include/tm27.h
nodist_include_HEADERS = include/bspopts.h
nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
DISTCLEANFILES = include/bspopts.h
noinst_PROGRAMS =
# wrapup is the one that actually builds and installs the library
# from the individual .rel files built in other directories
# XXX ignore tools since it doesn't build
SUBDIRS = .
include_HEADERS += ../../shared/tod.h
include_HEADERS += include/coverhd.h
include_HEADERS += include/page_table.h
nodist_include_HEADERS += $(top_srcdir)/../shared/mvme/mvme16x_hw.h
noinst_LIBRARIES = libbspstart.a
libbspstart_a_SOURCES = ../../m68k/shared/start.S
project_lib_DATA = start.$(OBJEXT)
dist_project_lib_DATA += startup/linkcmds
noinst_LIBRARIES += libbsp.a
libbsp_a_SOURCES =
# startup
libbsp_a_SOURCES += startup/bspclean.c ../../shared/bsplibc.c \
    ../../shared/bsppredriverhook.c ../../shared/bsppost.c \
    startup/bspstart.c ../../shared/bootcard.c  \
    ../../shared/bsppretaskinghook.c startup/page_table.c \
    ../../shared/bspgetworkarea.c startup/page_table.c \
    ../../shared/sbrk.c ../../m68k/shared/setvec.c \
    ../../shared/gnatinstallhandler.c
# clock
libbsp_a_SOURCES += clock/ckinit.c
# console
libbsp_a_SOURCES += console/console.c ../../shared/dummy_printk_support.c
# timer
libbsp_a_SOURCES += timer/timer.c timer/timerisr.S
# ADCDAC
adcdac/relaydrv.c
# tod
libbsp_a_SOURCES += tod/tod.c
if HAS_NETWORKING
network_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
noinst_PROGRAMS += network.rel
network_rel_SOURCES = ../mvme167/network/network.c
network_rel_CPPFLAGS = $(AM_CPPFLAGS) $(network_CPPFLAGS)
network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
endif
libbsp_a_LIBADD = \
    ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
    ../../../libcpu/@RTEMS_CPU@/shared/misc.rel
if HAS_NETWORKING
libbsp_a_LIBADD += network.rel
endif
if HAS_FPSP
libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/fpsp.rel
endif
EXTRA_DIST = times
include $(srcdir)/preinstall.am
include $(top_srcdir)/../../../../automake/local.am
4. I have included Header files in Drivers C Files (ADC.c, DAC.c etc)
   With
	#include <ADC.h>       	[ in adc.c   ]
	#include <DAC.h>  		[ in dac.c   ]
	#include <OPTO.h>		[ in opto.c  ]
	#include <RELAY.h> 		[ in relay.c ]
   Also modified ..\RTEMS\rtems-4.10.2\cpukit\sapi\include\condefs.h
   To include ADC /DAC Device Driver Header files and Driver Table entries
 just
   (like CONSOLE AND CLOCK DRIVER TABLE ENTRY points :
   /* Default Device Driver Table.  Each driver needed by the test is
explicitly
    *  choosen by that test.  There is always a null driver entry.
   The relevant part of this condefs.h file is as given below :
   #define NULL_DRIVER_TABLE_ENTRY \
     { NULL, NULL, NULL, NULL, NULL, NULL }
   #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
      #include <rtems/console.h>
   #endif
/******** ADDED BY MEDHAVI ***********************************/
#ifdef CONFIGURE_APPLICATION_NEEDS_ADC_DRIVER
  #include <adc.h>
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_DAC_DRIVER
  #include <dac.h>
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_OPTO_DRIVER
  #include <opto.h>
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_RELAY_DRIVER
  #include <relay.h>
#endif
/******** END OF ADDITION  MEDHAVI ***********************/
#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
  /* the ide driver needs the ATA driver */
  #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
    #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
  #endif
  #include <libchip/ide_ctrl.h>
#endif
And
#ifdef CONFIGURE_INIT
  rtems_driver_address_table Device_drivers[] = {
    #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
      CONFIGURE_BSP_PREREQUISITE_DRIVERS,
    #endif
    #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
      CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
    #endif
      CONSOLE_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
      CLOCK_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
      RTC_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
      WATCHDOG_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
      DEVNULL_DRIVER_TABLE_ENTRY,
    #endif
      IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
      ATA_DRIVER_TABLE_ENTRY,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
      FRAME_BUFFER_DRIVER_TABLE_ENTRY,
    #endif
	/*----- BEGINING : ADDED BY MEDHAVI ----------*/
      ADC_DRIVER_TABLE_ENTRY,
    #endif
      DAC_DRIVER_TABLE_ENTRY,
    #endif
      OPTO_DRIVER_TABLE_ENTRY,
    #endif
      RELAY_DRIVER_TABLE_ENTRY,
    #endif
	/*----- END : ADDED BY MEDHAVI --------------*/
    #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
      CONFIGURE_APPLICATION_EXTRA_DRIVERS,
    #endif
    #ifdef CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
    #elif !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) && \
        !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS)
    #endif
#endif
5. Then I have defined following in samples\hello\init.c :
	#define		CONFIGURE_APPLICATION_NEEDS_ADC_DRIVER
	#define		CONFIGURE_APPLICATION_NEEDS_DAC_DRIVER
	#define		CONFIGURE_APPLICATION_NEEDS_OPTO_DRIVER
	#define		CONFIGURE_APPLICATION_NEEDS_RELAY_DRIVER
   just to include ADC /DAC Header files and
6. Then after running configuration with following options :
   When I run “make – w  all”,I  have observed following ERRORs in
..\rtems-4.10.2\
   Testsuites\samples\hello\init.c
   I.  ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : adc.h
: No
     such file or directory
   II.  ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : dac.h
:No
   III. ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : opto.h :
  No such file or directory
   IV. ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : relay.h :
  :No such file or directory
  I have also found that makmefile.in and preinstall.am
          ..\rtems-4.10.2\c\src\lib\libbsp\ m68k\mvme162
  Have not been updated though I have modified makefile.am (in same
m68k]mvme162).
  My drivers source files like adcdrv.c and adc.h are not appearing in
makefile.in
  Though I have included ADC / DAC Device Driver C and Header files and
included
  these in relevant makefile.am just like CONSOLE and CLOCK Driver, I am
not sure why
  header files like adc.h are not included in makefile.in
  I have following queries regarding this problem :
1.why makmefile.in and preinstall.am are not updating (by generating
automatically by automake) as per modifications done in makefile.am
I believe that makefile.in and preinstall.am have to be automatically
get modified once we build RTEMS with modified makefile.am
2. What to do to get modified makefile.in and preinstall.am
3. Whether I have to modify some other makefiles / configuration files
Kindly provide your suggestions and solution to resolve the problem at the
earliest.
Further The Prototype Application for Testing ADC / DAC driver on
MVME162-522A is ready for Integration with RTEMS-4.10.2 and then testing
ADC/DAC Device Driver.
Best regards
AJAI KUMAR MEDHAVI
SCIENTIFIC OFFICER
RAJA RAMMANNA CENTRE FOR ADVANCED TECHNOLGY
DEPARTMENT OF ATOMIC ENERGY, GOV. OF INDIA,
PO : CAT, INDORE-452013, INDIA
PH. 91-731-2488052
Email : akmedhavi at rrcat.gov.in , akmedhavi at rediffmail.com
