No subject
Ziaulhaque Qazi ziaulhaque.qazi at sesame.org.jo
Wed Mar 28 12:37:29 UTC 2012
Hello All
I have been trying to build RTEMS-4.10.2 for mvme 2304 CPU.
First I tried to run an EPICS application but failed. I was advised to try first the example application which I tried today.
After configuring the CPU with NIOT command of PPC1BUG and running the NBO command for network booting with the file hello.exe, it loaded the file from tftp server but execution returned in error.
I am pasting below all that was on the hyperterminal screen (PPC1BUG commands and messages)
PPC1-Bug>niot
Controller LUN =00?
Device LUN     =00?
Node Control Memory Address =07F9E000?
Client IP Address      =10.1.22.45?
Server IP Address      =10.1.22.49?
Subnet IP Address Mask =255.255.255.0?
Broadcast IP Address   =0.0.0.0?
Gateway IP Address     =10.1.22.1?
Boot File Name ("NULL" for None)     =hello.exe?
Argument File Name ("NULL" for None) =?
Boot File Load Address         =001F0000?
Boot File Execution Address    =001F0000?
Boot File Execution Delay      =00000000?
Boot File Length               =00000000?
Boot File Byte Offset          =00000000?
BOOTP/RARP Request Retry       =00?
TFTP/ARP Request Retry         =00?
Trace Character Buffer Address =00000000?
BOOTP/RARP Request Control: Always/When-Needed (A/W)=W?
BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: hello.exe
Client IP Address      = 10.1.22.45
Server IP Address      = 10.1.22.49
Gateway IP Address     = 10.1.22.1
Subnet IP Address Mask = 255.255.255.0
Boot File Name         = hello.exe
Argument File Name     =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&2983080, Bytes Loaded =&2983080
Bytes/Second   =&149154, Elapsed Time =20 Second(s)
Residual-Data Located at: $07F88000
Exception: Program (Illegal Instruction)
SRR0 =00005000 SRR1 =00083040 Vector-Offset =00700
IP     =00005000 MSR    =00003040 CR     =00000000 FPSCR  =00000000
R0     =00000000 R1     =07F88000 R2     =00000000 R3     =07F88000
R4     =00005000 R5     =00000000 R6     =00000000 R7     =00000000
R8     =00000000 R9     =00000000 R10    =00000000 R11    =00000000
R12    =00000000 R13    =00000000 R14    =00000000 R15    =00000000
R16    =00000000 R17    =00000000 R18    =00000000 R19    =00000000
R20    =00000000 R21    =00000000 R22    =00000000 R23    =00000000
R24    =00000000 R25    =00000000 R26    =00000000 R27    =00000000
R28    =00000000 R29    =00000000 R30    =00000000 R31    =00000000
SPR0   =00000000 SPR1   =00000000 SPR8   =00000000 SPR9   =00000000
00005000 7F454C46  WORD        $7F454C46
PPC1-Bug>
I need guidance to find what could be the possible problem there?
While installing the tool-chain, gcc and rtems I did not face any problem or error. I had been installing it successfully many times before this one, so I am confident about RTEMS and Toolchain. However I need expert opinion.
This time while installing RTEMS for MVME2304, I just copied the files for MVME2307 with the names of MVME2304 to get the bsp supported.
Please guide me if I was right in doing that.
Zia
URL: <http://lists.rtems.org/pipermail/users/attachments/20120328/eb66a2c1/attachment.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.rtems.org/pipermail/users/attachments/20120328/eb66a2c1/attachment.gif>
