Problem in Integration of Analog / Digital Drivce driver with RTEMS for MVME162-522A
Wed Mar 28 12:39:48 UTC 2012
My recollection would indicate these peripherals are not on the 162 board. These never should have been merged into the rtems source tree and modifying confdefs.h to get them is not riht unless you are proposing standard ways for everyone to follow.
Build the drivers in your application space somehow and add them with the confdefs.h parameter which is named something like CONFIGURE_EXTRA_APPLICATION_DRIVERS.
--joel
AJAI KUMAR MEDHAVI <akmedhavi at rrcat.gov.in> wrote:
>Hi,
>I have made Analog / Digital IO ( ADC, DAC, OPTO and Relay)  Device
>drivers for MVME162-512 VME CPU Board using RTEMS 4.10.2 on Windows with
>MinGW-get-inst-20110802 and RTEMS4.10 tools
>Before integrating ADC / DAC Drivers, I have successfully configured,
>build and run all sample and test applications on my CPU board.
>Now I have added ADC/DAC Device Drivers for Four IO boards i.e ADC, DAC,
>RELAY and OPTO. I have integrated Device Driver files in following steps :
>1. First created a new folder ADCDAC in
>               ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162
>   And added following Files
>	ADC.c
>	DAC.c
>	OPTO.c
>	RELAY.c
>   in ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162\ADCDAC directory.
>2. Then modify makefile.am in   ..\rtems-4.10.2\c\src\lib\ libbsp\ m68k\
>   mvme162
>   With
># ADCDAC
>libbsp_a_SOURCES += adcdac/adcdrv.c adcdac/dacdrv.c adcdac/optodrv.c \
>		     adcdac/relaydrv.c
>   to include ADC/DAC C files in makefile.
>3. Then added Header files adc.h, dac.h, opto.h and realy.h
>          In ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162\include
>   And modify makefile.am in   ..\rtems-4.10.2\c\src\lib\ libbsp\ m68k\
>                                mvme162
>   With
>	include_bspdir = $(includedir)/bsp
>	dist_project_lib_DATA = bsp_specs
>	include/adc.h include/dac.h include/opto.h include/relay.h
>The modified makefile.am in ..\rtems-4.10.2\c\src\lib\libbsp\m68k\mvme162
>is :
>## $Id: Makefile.am,v 1.42 2008/09/30 10:32:49 ralf Exp $
>ACLOCAL_AMFLAGS = -I ../../../../aclocal
>include $(top_srcdir)/../../../../automake/compile.am
>include_HEADERS = include/bsp.h include/adc.h include/dac.h include/opto.h
>include/relay.h
>include_HEADERS += include/tm27.h
>nodist_include_HEADERS = include/bspopts.h
>nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>DISTCLEANFILES = include/bspopts.h
>noinst_PROGRAMS =
># wrapup is the one that actually builds and installs the library
># from the individual .rel files built in other directories
># XXX ignore tools since it doesn't build
>SUBDIRS = .
>include_HEADERS += ../../shared/tod.h
>include_HEADERS += include/coverhd.h
>include_HEADERS += include/page_table.h
>nodist_include_HEADERS += $(top_srcdir)/../shared/mvme/mvme16x_hw.h
>noinst_LIBRARIES = libbspstart.a
>libbspstart_a_SOURCES = ../../m68k/shared/start.S
>project_lib_DATA = start.$(OBJEXT)
>dist_project_lib_DATA += startup/linkcmds
>noinst_LIBRARIES += libbsp.a
>libbsp_a_SOURCES =
># startup
>libbsp_a_SOURCES += startup/bspclean.c ../../shared/bsplibc.c \
>    ../../shared/bsppredriverhook.c ../../shared/bsppost.c \
>    startup/bspstart.c ../../shared/bootcard.c  \
>    ../../shared/bsppretaskinghook.c startup/page_table.c \
>    ../../shared/bspgetworkarea.c startup/page_table.c \
>    ../../shared/sbrk.c ../../m68k/shared/setvec.c \
>    ../../shared/gnatinstallhandler.c
># clock
>libbsp_a_SOURCES += clock/ckinit.c
># console
>libbsp_a_SOURCES += console/console.c ../../shared/dummy_printk_support.c
># timer
>libbsp_a_SOURCES += timer/timer.c timer/timerisr.S
># ADCDAC
>adcdac/relaydrv.c
># tod
>libbsp_a_SOURCES += tod/tod.c
>if HAS_NETWORKING
>network_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
>noinst_PROGRAMS += network.rel
>network_rel_SOURCES = ../mvme167/network/network.c
>network_rel_CPPFLAGS = $(AM_CPPFLAGS) $(network_CPPFLAGS)
>network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>endif
>libbsp_a_LIBADD = \
>    ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
>    ../../../libcpu/@RTEMS_CPU@/shared/misc.rel
>if HAS_NETWORKING
>libbsp_a_LIBADD += network.rel
>endif
>if HAS_FPSP
>libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/fpsp.rel
>endif
>EXTRA_DIST = times
>include $(srcdir)/preinstall.am
>include $(top_srcdir)/../../../../automake/local.am
>4. I have included Header files in Drivers C Files (ADC.c, DAC.c etc)
>   With
>	#include <ADC.h>       	[ in adc.c   ]
>	#include <DAC.h>  		[ in dac.c   ]
>	#include <OPTO.h>		[ in opto.c  ]
>	#include <RELAY.h> 		[ in relay.c ]
>   Also modified ..\RTEMS\rtems-4.10.2\cpukit\sapi\include\condefs.h
>   To include ADC /DAC Device Driver Header files and Driver Table entries
> just
>   (like CONSOLE AND CLOCK DRIVER TABLE ENTRY points :
>   /* Default Device Driver Table.  Each driver needed by the test is
>explicitly
>    *  choosen by that test.  There is always a null driver entry.
>   The relevant part of this condefs.h file is as given below :
>   #define NULL_DRIVER_TABLE_ENTRY \
>     { NULL, NULL, NULL, NULL, NULL, NULL }
>   #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>      #include <rtems/console.h>
>   #endif
>/******** ADDED BY MEDHAVI ***********************************/
>#ifdef CONFIGURE_APPLICATION_NEEDS_ADC_DRIVER
>  #include <adc.h>
>#endif
>#ifdef CONFIGURE_APPLICATION_NEEDS_DAC_DRIVER
>  #include <dac.h>
>#endif
>#ifdef CONFIGURE_APPLICATION_NEEDS_OPTO_DRIVER
>  #include <opto.h>
>#endif
>#ifdef CONFIGURE_APPLICATION_NEEDS_RELAY_DRIVER
>  #include <relay.h>
>#endif
>/******** END OF ADDITION  MEDHAVI ***********************/
>#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
>  /* the ide driver needs the ATA driver */
>  #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
>    #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
>  #endif
>  #include <libchip/ide_ctrl.h>
>#endif
>And
>#ifdef CONFIGURE_INIT
>  rtems_driver_address_table Device_drivers[] = {
>    #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
>      CONFIGURE_BSP_PREREQUISITE_DRIVERS,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
>      CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
>    #endif
>      CONSOLE_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>      CLOCK_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
>      RTC_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
>      WATCHDOG_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
>      DEVNULL_DRIVER_TABLE_ENTRY,
>    #endif
>      IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
>      ATA_DRIVER_TABLE_ENTRY,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
>      FRAME_BUFFER_DRIVER_TABLE_ENTRY,
>    #endif
>	/*----- BEGINING : ADDED BY MEDHAVI ----------*/
>      ADC_DRIVER_TABLE_ENTRY,
>    #endif
>      DAC_DRIVER_TABLE_ENTRY,
>    #endif
>      OPTO_DRIVER_TABLE_ENTRY,
>    #endif
>      RELAY_DRIVER_TABLE_ENTRY,
>    #endif
>	/*----- END : ADDED BY MEDHAVI --------------*/
>    #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
>      CONFIGURE_APPLICATION_EXTRA_DRIVERS,
>    #endif
>    #ifdef CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
>    #elif !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) && \
>        !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS)
>    #endif
>#endif
>5. Then I have defined following in samples\hello\init.c :
>	#define		CONFIGURE_APPLICATION_NEEDS_ADC_DRIVER
>	#define		CONFIGURE_APPLICATION_NEEDS_DAC_DRIVER
>	#define		CONFIGURE_APPLICATION_NEEDS_OPTO_DRIVER
>	#define		CONFIGURE_APPLICATION_NEEDS_RELAY_DRIVER
>   just to include ADC /DAC Header files and
>6. Then after running configuration with following options :
>   When I run “make – w  all”,I  have observed following ERRORs in
>..\rtems-4.10.2\
>   Testsuites\samples\hello\init.c
>   I.  ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : adc.h
>: No
>     such file or directory
>>   II.  ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : dac.h
>:No
>   III. ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : opto.h :
>  No such file or directory
>   IV. ../../../../../mvme162/lib/include/rtems/confdefs.h  Error : relay.h :
>  :No such file or directory
>  I have also found that makmefile.in and preinstall.am
>          ..\rtems-4.10.2\c\src\lib\libbsp\ m68k\mvme162
>  Have not been updated though I have modified makefile.am (in same
>m68k]mvme162).
>  My drivers source files like adcdrv.c and adc.h are not appearing in
>makefile.in
>  Though I have included ADC / DAC Device Driver C and Header files and
>included
>  these in relevant makefile.am just like CONSOLE and CLOCK Driver, I am
>not sure why
>  header files like adc.h are not included in makefile.in
>  I have following queries regarding this problem :
>1.why makmefile.in and preinstall.am are not updating (by generating
>automatically by automake) as per modifications done in makefile.am
>I believe that makefile.in and preinstall.am have to be automatically
>get modified once we build RTEMS with modified makefile.am
>2. What to do to get modified makefile.in and preinstall.am
>3. Whether I have to modify some other makefiles / configuration files
>Kindly provide your suggestions and solution to resolve the problem at the
>earliest.
>Further The Prototype Application for Testing ADC / DAC driver on
>MVME162-522A is ready for Integration with RTEMS-4.10.2 and then testing
>ADC/DAC Device Driver.
>Best regards
>AJAI KUMAR MEDHAVI
>SCIENTIFIC OFFICER
>RAJA RAMMANNA CENTRE FOR ADVANCED TECHNOLGY
>DEPARTMENT OF ATOMIC ENERGY, GOV. OF INDIA,
>PO : CAT, INDORE-452013, INDIA
>PH. 91-731-2488052
>Email : akmedhavi at rrcat.gov.in , akmedhavi at rediffmail.com
