rtems git readonly access behind corporate firewall
Cláudio Silva claudiodcsilva at gmail.com
Thu Mar 29 18:37:26 UTC 2012
Hi Jeff,
git clone http://git.rtems.org/rtems rtems works for me.
There were some problems earlier today in the RTEMS git repository.
You probably tried to clone when those issues were being solved by
Joel and therefore you got cloning errors.
Please try again. It should work.
Regards,
Cláudio
On Thu, Mar 29, 2012 at 7:13 PM, Hill, Jeffrey O <johill at lanl.gov> wrote:
> Hi,
> I am attempting to use the RTEMS git repository but the following recommended command doesn't work.
>> git clone git://git.rtems.org/rtems.git rtems
> We have a corporate firewall here so it appears that I am forced to use one of the following commands instead (emphasis on http) after configuring the proper http proxy in git, but neither of these attempts are successful. There is an "rtems" but not an "rtems.git" at http://git.rtems.org/.
> clone http://git.rtems.org/rtems.git rtems
> The first command above results in a the following message.
> "warning: remote HEAD refers to nonexistent ref, unable to checkout."
> The second command above results in long delays and eventually a message about the connection being reset by its peer.
> I admit to being a git newbie so maybe someone will immediately recognize what I am doing wrong.
> Jeff
> rtems-users mailing list
> rtems-users at rtems.org
