Regarding compilation of RTEMS for sis
Thu Mar 1 17:50:27 UTC 2012
Please post the version of RTEMS you are using, the commands you used
to configure RTEMS, and check the output from running bootstrap or
configure for an error.
It sounds like configure failed. Maybe tools are out-of-date or for
the wrong version of RTEMS... The above info should help determine the
problem more precisely.
-Gedare
On Thu, Mar 1, 2012 at 12:33 PM, Ankit Laddha <ankit1991laddha at gmail.com> wrote:
> Hi all
> I am student and wanted to take part in Google Sumer of Code 2012 with
> RTEMS. I am using Ubuntu 11.10 as my operating System. I have compiled the
> GCC and Binutils as described at
> http://www.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu but
> after that when i tried to build RTEMS(Which i got by checking out the git
> repository) form sis as described in the Quick Start guide at
> http://www.rtems.org/wiki/index.php/Quick_Start i got the following error
> Making all in generic
> make[2]: Entering directory
> `/home/ankit/rtems-home/b-rtems/tools/cpu/generic'
> make[2]: Nothing to be done for `all'.
> make[2]: Leaving directory
> make[2]: Entering directory `/home/ankit/rtems-home/b-rtems/tools/cpu'
> make[2]: Nothing to be done for `all-am'.
> make[2]: Leaving directory `/home/ankit/rtems-home/b-rtems/tools/cpu'
> make[1]: Leaving directory `/home/ankit/rtems-home/b-rtems/tools/cpu'
> Making all in testsuites/tools
> make[1]: Entering directory
> `/home/ankit/rtems-home/b-rtems/testsuites/tools'
> make[1]: *** No rule to make target `all'.  Stop.
> make[1]: Leaving directory `/home/ankit/rtems-home/b-rtems/testsuites/tools'
> make: *** [all-recursive] Error 1
> Please help me to understand the problem in my Installation of tools or
> building process.
> Thanks in Advance.
> Ankit Laddha
> Junior Undergraduate
> Elec. Engg.Dept.
> IIT Delhi
> Problems worthy of attack prove their worth by fighting back.
> rtems-users mailing list
> rtems-users at rtems.org
