Starting with RTEMS
Binkowski, Cassio
cassioiks at gmail.com
Sun Mar 4 15:14:51 UTC 2012
On Sun, Mar 4, 2012 at 3:44 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 4/03/12 9:26 AM, Binkowski, Cassio wrote:
> I have done the process all over again but still accusing that there is
>> no g++ and c++.
> What is reporting it cannot find g++ and c++ ?
Ok, the exact lines are the following:
checking for avr-rtems4.10-g++... no
configure: error: no acceptable c++ found in $PATH
configure: error:
../../../../../../rtems-4.10.2/c/src/../../testsuites/samples/
configure failed for samples
configure: error: /bin/sh
'../../../../../rtems-4.10.2/c/src/../../testsuites/co
nfigure' failed for ../../testsuites
make[2]: *** [avrtest] Error 1
make[2]: Leaving directory
`/c/opt/rtems-4.10/rtems4.10-build/avr-rtems4.10/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
make: *** [all-recursive] Error 1
These the last lines of a large dump generated by the command "make all".
>> Would it be better if I download an image and run it with virtual box?
> Is this GSoC or something else ?
No, it isn't. I'm just trying to work my way through with RTEMS because
I'll be using RTEMS for my college final paper.
And I have been doing everything it says in the wiki.
I just can't tell if RTEMS was built correctly and I can't build the sample
application. So I was thinking a ready to go development environment should
be the best call then.
> Also, if I were to compile the hello_world_c sample app. Where should I
>> put this hello_world_c folder?
> It is in the build output tree. It you run 'find . -name \*.exe' at a
> shell prompt you will be given a list.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20120304/e97ae62a/attachment-0001.html>
