Building project - Eclipse
Binkowski, Cassio
cassioiks at gmail.com
Mon Mar 12 15:26:36 UTC 2012
On Mon, Mar 12, 2012 at 11:18 AM, 阿四 <ashi08104 at gmail.com> wrote:
> hi, since you are do cross-compiling, I think the call to gcc is not right.
> > Building file: ../init.c
> > Invoking: RTEMS C Compiler
> > /opt/rtems-4.11/bin/gcc -Os -g -Wall -c -fmessage-length=0 -pipe -MMD -MP
> accordding to your target, sparc-rtems4.11-gcc should be called.
I tried to replace the path in C/C++ build > Settings
for sparc-rtems4.11-gcc, instead of just gcc.
It just changes back to the original thing.
I don't know how to make it call sparc-rtems4.11-gcc. Can you help?
> best regards!
> zw_yao
URL: <http://lists.rtems.org/pipermail/users/attachments/20120312/d9f798f6/attachment-0001.html>
